Sponsored by: Auxito
Weird gauge problems
Old Nov 17, 2005 | 12:07 PM
bryan_1980's Avatar
bryan_1980
Question Weird gauge problems
Here's a weird problem I've been having the last few days. Whenever I start my truck, the speedometer and tachometer peg-out. It's similar to when you start the truck after the battery has been disconnected. Also, when it did this the first time, the "theft" light flashed rapidly after the truck started. When that happened, I turned the truck off, and re-started it, which stopped the light from flashing. I'm just wondering if there might be something wrong with the computer.
BTW, I've only noticed this happening since it's been colder out, around 30 degrees or so.
'99 F-150 S-cab, 5.4L, 2WD, 65000 miles
Old Nov 17, 2005 | 01:27 PM
BillyBob69's Avatar
BillyBob69
There was another post with this same issue. The fix was replacing the battery. Your truck will do this if the battery is not keeping a charge correctly.
Old Nov 17, 2005 | 06:43 PM
LxMan1's Avatar
LxMan1
Yep, weak battery on start-up will do this.
Old Nov 18, 2005 | 07:37 AM
bryan_1980's Avatar
bryan_1980
Thanks for the help!
Probably about time for a new one, anyways
Old Nov 18, 2005 | 04:56 PM
triton_2002's Avatar
triton_2002
Yep, battery's gonna die soon, get a new one before you get standed.
Old Jun 17, 2010 | 12:26 PM
dm ford rebal's Avatar
dm ford rebal
i just got a new batt still none working
Old Jun 17, 2010 | 12:27 PM
dm ford rebal
if you kno any thing let me kno
dm ford rebal
truck is a 92 f150 4x4 351
Old Jun 17, 2010 | 12:28 PM
dm ford rebal
o ya and the reverse lights stop to
Old Jun 17, 2010 | 12:29 PM
dm ford rebal
and no its not a fuse
