Can someone tell me the towing capacity for a 1988 F-150 4x4 long bed standard cab truck with a 3.55 rear and automatic, 5.0 engine? I have searched everywhere and can not find that year ratings anywhere. Looking to get a class III or IV hitch to tow a car trailer with a 1978 Malibu, approx 3000 lbs. Can I do this? Need to tow about 60 miles.
There should be a door tag listing the GCWR. This would be the total weight of everything you could travel with (PER Ford). This would be the weight of the truck, passengers, everything in bed of truck, trailer, everything on trailer. Without knowing for sure the trailer weight I feel that you would be maxed out or even over for a 1988.
Take this GCWR with a grain of salt as it is rarely accurate with that class of vehcle. With a 302 with a 3.55 rear axle, maybe about 4K or so. You might tow a bit more but it depends on terrain and trailer type. If you are thinks about a 5 or 6K travel trailer, forget it because the weight and drag together would make for a bad experiance while a low drag 5 k load car traile might do fairly well on reasonable flat ground. ALso what you can tow is not set in stone because if you regear your truck you can increase its real world towing capacity a good bit at times.
GCWR is not on the door tag in these trucks, just the GVWR, which is how much the truck alone can weigh. GCWR is in the owner's manual for the truck of that year and is in tables that are based on auto/man tranny, engine, 4x4/4x2, and rear end ratio. There are also some limitations based on whether you have "Super Cooling", "Trailer Tow Package" and "Handling/Suspension Package". Without any of those, you're limited to 2000 lbs. Limit is 3500 with the S/C, and 7700lbs. with everything.
This is all from the '90 owners manual, but I imagine the '88 is pretty close to that. I once towed a U-Haul tandem auto trailer with a '74 Jeep on it 550 miles with my '90 F150 (302, 3.55, AOD, 4x2). I regretted it. I think both my engine and tranny lost a large part of their life from that trip. Both were replaced within 2-3 years.
I'll argree with leader on this one! put a ball on the thing and go! We towed a 6-8k TT with an 86 F150 with the 302 and 3.73s and although we didn't break any speed limits we could maintain 60mph without to much problem. We weren't towing in hills and the trip was only 50-60 miles so we didn't worry about it to much. The bumper that was on the 86' was plenty strong for 5k and I think underrated as already was stated. If you want a little added security go ahead and put on hitch but don't worry about the truck.
Wow! I feel much better now knowing my purchase was not wasted as that was the sole purpose I bought the truck for. I think I will go ahead and add a class III or IV hitch on it and try it.
Thanks for all the replies.
