Sponsored by: Auxito
studdering issues
Old Nov 17, 2005 | 03:09 AM
TCELasVegas's Avatar
TCELasVegas
studdering issues
I have a 99 F-150 2 wheel drive with a 4.6 eng and an automatic trans. I am having an issue with it cutting out at different speeds. I have replaced the fuel filter and air cleaner and trying to figure out the next step. I pluged in my computer to the truck and it is saying I have misfiring in cylinders 1,2, & 4. Any advise would help.
Thank you, Todd
Old Nov 17, 2005 | 07:55 AM
peppermrj's Avatar
peppermrj
How many miles? Plugs, wires/cop boots, etc?
Old Nov 17, 2005 | 12:38 PM
TCELasVegas
96,000 mls on eng. and wires were replaced 10,000 mls ago
Old Nov 17, 2005 | 01:00 PM
peppermrj's Avatar
peppermrj
If the plugs and wires are good the next thing i would check is an O2 sensor for that bank of cylinders. A crank position sensor would cause it to die at speed.
Also check for any vacuum leaks or lose electrical connections.
good hunting.
Old Nov 17, 2005 | 10:17 PM
ccoram's Avatar
ccoram
Swap the coil packs and see if the misfire changes cylinders. If so, you have a bad coil pack. Also could possibly be fuel pump, fuel filter, fuel injectors, bad gas, or bad spark plugs/wires even though they arent that old. I'd swap the coils first thing, clear my codes and see if the misfiring cylinders change.
Old Nov 19, 2005 | 07:07 PM
TCELasVegas
Thank you for the help I fouund it to be a hairline crack in #2 spark plug. Changened them all and her truck is roaring again. Now I now why I drive a deisel. Thank you
Todd
Old Nov 19, 2005 | 07:13 PM
peppermrj's Avatar
peppermrj
Hmm. Thanxs for the update.
