Engine looses power on acceleration
Old Nov 16, 2005 | 09:53 PM
400exblaster's Avatar
400exblaster
Unhappy Engine looses power on acceleration
I have a 89 ford f-150 with a 4.9L and it will loose power when i accerlerate. I hear a clicking noise when i get on the gas but i cannot hear it at idle. I get really bad gas milage. I'm not sure but i'm about ready to drop another engine in if i can't figure it out. I think it could be a lifter or valve but I want to make sure before i go to the trouble. I was wandering if anyone could figure it out. THanks
Old Nov 16, 2005 | 10:05 PM
optikal illushun's Avatar
optikal illushun
was it tuned up recently? (plugs, wires, cap, rotor, fuel filter)
was the o2 sensor ever replaced?
what is the timing set at?
did u perform a compression test?
did u perform a leak down test?
u can also tell the condition of the engine by its intake manifold vacuum. check this link out: http://www.users.bigpond.com/ergoff/vac1.htm
gives a good description on what readings are good, bad and how to perofrm them.
Kwikkordead
62
Jan 15, 2011 02:40 PM
sunuvabug
Aug 21, 2006 03:38 PM
CONFTIM1
May 31, 2006 08:04 AM
77Fordf100
Mar 2, 2006 06:21 AM
terrapin88
25
Feb 15, 2006 06:08 PM
