key fob
Old Nov 16, 2005 | 08:55 PM
tfdcapt's Avatar
tfdcapt
key fob
Anyone know how to reprogram a keyfob for a 2000 f-250SD
Old Nov 16, 2005 | 09:29 PM
00250diesel's Avatar
00250diesel
ya i just had to do mine i called the stealership and they wanted 40 bucks to do so i found out how to do it myself all you have to do is cycle the ignition 5 times the doors will lock and unlock then push a button on the remote and they will cycle again and you are done
to cycle ignition do not turn truck on just in run but it has to be done within 20 seconds or something like that
Old Nov 16, 2005 | 11:30 PM
Powerstrokedlariat's Avatar
Powerstrokedlariat
Turn the ignition from off to run 5 times within 10 seconds, with the fifth time ending in run, all door locks will lock and then unlock to confirm programming mode, press any button on transmitter. Door locks will cycle to confirm programming. Press any button on second transmitter (up to 4 can be done) Turn ignition off. Ready to go!!! I just did mine and I have the dealer instructions with me still. This is verbatim-
Old Nov 16, 2005 | 11:56 PM
SpringerPop's Avatar
SpringerPop
I believe the procedure is right in the owner's manual.
Pop
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
