Hard start 99 x !
Old Nov 16, 2005 | 04:32 PM
crown's Avatar
crown
Hard start 99 x !
I have a 1999 explorer that starts fine one minute. And then turns over but won't start the next. 4.0L OHV Auto 4X4. This is causing a lot of grief for the little lady. PLEASE HELP!
Old Nov 16, 2005 | 08:13 PM
srercrcr's Avatar
srercrcr
Some Explorers, including mine lately, have experienced INTERMITTENT failure to kick over....meaning everything is fine for weeks/months, then one day it cranks just fine, but doesn't kick over or even seem like it wants to try. You'll need to read up on past posts cause different people have had different luck with EEC relay, fuel pump relay, bad connection at the PCM. Mechanics won't be able to help unless it's doing it when in their hands. Someone recently told me that when you first turn the key and the dash lights come on, check to see if the "check engine" light is on. If not, try to start it. If it just cranks, that's a sign it has something to do with the PCM or connections
