Generator in '64
Old Nov 16, 2005 | 02:24 PM
jethro1's Avatar
jethro1
Generator in '64
When I installed a new 223 engine in my '64 F-100, I think I may have reversed the field wires on the generator. I'm installing a new voltage regulator. How do I make sure I have the wires right on the generator? Any color coding on the wires is completely faded.
Old Nov 16, 2005 | 04:53 PM
alchymist's Avatar
alchymist
"Mifflin Clay"
Trace them from the regulator. If I'm not mistaken, (IF I am someone will correct me!) the regulator is marked F & A for field and Armature. Generator should be also. Just follow or "ring out" the wires with a test light before installing. Incidentally, you should "flash" the generator when you install it.
If memory serves, it was an instantaneous connection from battery + to field terminal, causing a momentary current to magnetize the field poles. (Boy, am I going back for that one).
Old Nov 17, 2005 | 11:29 AM
jethro1's Avatar
jethro1
Thanks, alchymist. I think the procedure for "flashing" the generator is covered in the shop manual. "ring out"??
Old Nov 17, 2005 | 02:14 PM
alchymist's Avatar
alchymist
"Mifflin Clay"
"Ring out" means to check with an ohmmeter or test light by connecting to one end of a bunch of wires and then locating the other end by trying all the other loose ends until one indicates on the meter or the test light lights. Electronic term, I think it came originally from the telephone co......
