stainless steel vs. grade 8
Here's a little info on s/s:
http://en.wikipedia.org/wiki/Stainless_steel
http://totallystainless.net/totally.html
(click on "ABOUT STAINLESS STEEL") on the second link.
Personally, I like the idea of bolts because you can dis-assemble much easier than with rivets.
Originally Posted by Plowdude
I beat all the rivets out of my frame. I heard that stainless steel bolts are as strong as grade 8. Is this true? I would like to put in stainless but if im going to compromise strength over looks, Ill stay with grade 8.
When replacing frame rivets with bolts, you want an exact fit. In my opinion, this is just as important as the type of bolt you use.
Any slack at all between the hole and the bolt will eventually cause the bolt or hole to wear as the frame flexes.
One of the reasons they dont use bolts in frames at the factory is that the bolt holes would need to be reamed to fairly tight tolerances. Rivets expand to make a tight fit as they are peened into place. Thats why you have to beat them out.
Stainless steel is strong and has good wear factors, but tends to be soft and is not as hard as a rivet or grade 8 bolt. What ever you use to replace rivets, they need to be pressed in or driven in, so as to prevent any slack in the holes they are fitted in. Loose bolts will work loose and cause a wobbling.
