97 Expediton down shift problems
Old Nov 16, 2005 | 10:20 AM
gctiger's Avatar
gctiger
Ex. When I'm in bumper to bumper traffic and start to move foward say 5-10mph and let off the gas to slow down I have a huge knock (that you feel and hear) in the rear end when it down shifts. This happens only when I'm at these slow speeds. Any advice as to what might be causing this? I've checked the dope in the rear end and it is at the required level.
Old Nov 25, 2005 | 12:28 AM
REBBLE187's Avatar
REBBLE187
i have the same problem....
my 98 expy xlt rumbles for a second when i step on the pedal and rpm downshifts going on the highway 50-60 mph. this doesnt happen to me on the streets. anyway, my check engine light is not on so i havent dont anything but i know for sure that this is not normal.
let me know if you know the answer to this. thanks. im thinking is probably the transmission. when was the last time you did a trans. tuneup?
Old Nov 26, 2005 | 12:58 AM
Greenscobie86's Avatar
Greenscobie86
I dont have this problem, but maybe the rear driveshaft u joints are going bye bye. Just a thought.
Old Dec 8, 2005 | 03:43 PM
ski38off2005's Avatar
ski38off2005
interesting...
I have the same problem with the rumble right around 50-60 mph. I notice it is worse if you are accelerating gradually, and better if you punch it. It seems like there's a difference between if you are moving down one or two gears (ie into third vs. second). I guess I just figured it was the tranny going (I do have 230K on the truck), but keep me posted as to what you find out!
By the way, does your shake when going around turns on the highway? Mine does, dealer says the tires are cupping, but can't tell me why.
Old Dec 8, 2005 | 11:46 PM
skier-24's Avatar
skier-24
I wonder how many people know what "ski38off" means. I do.
Old Dec 9, 2005 | 01:06 AM
ski38off2005
Awesome. Can you get there?? I can't. Yet. Best so far is 32 off...but working hard at it!
Old Dec 9, 2005 | 05:13 AM
skier-24's Avatar
skier-24
I can't get it either an don't have access to a slalom course anymore.
As far as the mechanical problems, I'd check universal joints and ball joints. My ball joints were replaced at 86,000.
Old Dec 9, 2005 | 02:00 PM
montero91's Avatar
montero91
my '99 rumbles prior to downshift at 50-60 and was told it might be the egr valve and you can take these off and clean them.
Old Dec 9, 2005 | 02:06 PM
montero91's Avatar
montero91
check the motor mounts, the motor may be lifting due to torque and then thumping when you let off the gas.
