Alright this all starts with me. a 15 yea old buyin a truck. it happened to be a 87 f150 with a 302 v8... so i bought the truck and it ran.... bout when you gave it alot of gas it sputterd and nuthing would happen then it got worse i would floor it and go no where whats happenin? is it worth the money to try and fix it?
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have here. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
hey i know about trucks i just wantto know if it could be my injectors fuel pump...has new plugs dont know what else i could do.... i can rev the pis out of it in nuetral but when i put it in gear it bogs
Injectors could be clogged, fuel filter may need changed, cats could be clogged. You may also have bad gas or alot of water in your gas. Your timing could be off. You may have other problems with your ignition system, too. There is a number of things it could be.
