Sponsored by: Real Truck
4X4 Hub
Old Nov 15, 2005 | 12:31 PM
jimmytree's Avatar
jimmytree
Question 4X4 Hub
Hi All,
How big a job and any special tools needed to fix locking hub on 2000 F450. Hub won't lock.
Thanks, Jim
Old Nov 15, 2005 | 05:32 PM
jim henderson's Avatar
jim henderson
I DO NOT know your model, but in general you will probably need one of those special sockets with the 2 or 4 or more "ears" on them to turn the locking nut. You will probably need an air or electric impact wrench. They are model and sometimes year and axle specific. I actually needed two slightly different ones for the front and rear of my truck, eventhough they are supposed to use the same socket.
On my 94 the hardest parts are removing the locking nut since it requires the wrench and a LOT of torque, something like 250 foot pounds. I spent a week trying with every breaker bar etc I had and couldn't budge it. Impact wrench, took 10 seconds, dang.
One other gotcha at least on my 94... there is a retaining ring that is about the size and shape of a piston ring that sits in a groove on the inside of the hub maybe 1/4 inch in from the rim. It is almost impossible to see due to grease, but you can feel it. You need to get something to pick the end of the ring out of the groove and then the rest is easy. I recall using a machinists scribe. Took me a few days to figure that one out. I am slow.
Yours might have an alignment pin that fits in a hole on the large washer that the locknut fits against. Make sure you mate the pin to a hole, otherwise you will break it and have to figure out how to make one.
Other than that, the hub is a pretty simple piece of gear. Lube the locking hub assembly, very lightly. It does NOT need much grease. Might as well lube the wheel bearings since they will be right there by this point.
Good Luck,
Jim Henderson.
Old Nov 15, 2005 | 07:50 PM
Steve_250's Avatar
Steve_250
Check this post, it's about replacing ball joints but tells ya how to do the hubs.
Racerguy did an excellent write up on it!
https://www.ford-trucks.com/forums/s...light=racerguy
Old Nov 15, 2005 | 09:25 PM
skinner00's Avatar
skinner00
are you just replacing the locking hub? if so it is one clip
kissfan79
Feb 11, 2014 01:50 PM
jck_strw
Mar 7, 2008 05:51 PM
fire19
Feb 2, 2006 06:57 AM
ironmine
Nov 16, 2005 08:51 AM
jim henderson
May 19, 2002 06:31 PM
