can anyone help with some wiring problems?
Old Nov 15, 2005 | 11:40 AM
dizturbed83's Avatar
dizturbed83
Unhappy can anyone help with some wiring problems?
i recently bought a '79 f-150ranger and i have no blinkers no dash lights and the fuel guage does not work.i am leaning towards a bad ground behind the dash but i am not to confident when it comes to wiring problems so any help would be greatly appreciated.also the instrument panel fuse keeps blowing out.
Old Nov 15, 2005 | 11:57 AM
Pony Power's Avatar
Pony Power
instrument panel fuse keeps blowing out. [Most likely a hot wire grounding out] Check under the dash and rear of dash panel for starters for bare or hot wires touching ground. Look for previous repairs where wires are taped together, sometimes sloppy work comes apart.
no blinkers. [Do you have tail lights? Brakes and turn signal are on one line and tail lights on another] You need to get a electrical probe tester, [like an ice pick with a wire] It's possible that you may have burned out all of the bulbs but a tester is a must to figure it out.
Good luck
Old Nov 16, 2005 | 06:16 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Nov 16, 2005 | 07:45 AM
olfordsnstone's Avatar
olfordsnstone
I wouldn't think that a bad ground would cause the fuse to blow. Seems to me that you have a short, (or positive (+) wire grounding out to body metal as PP stated). Look for something like Pony Power has described. Any bare wire should be properly connected (or at least taped) as it may swing or move with vehicular movement etc and short out. Could also be a faulty component with an internal short. More than likely a short from a positive wire.
Old Nov 16, 2005 | 08:22 AM
dizturbed83
thank you for replying...i will just have to start tracing and see if i find anything.
Old Nov 16, 2005 | 09:15 PM
yield2s's Avatar
yield2s
stick your hand up behind the gauges and grab them. if the white plastic mold falls apart in your hand then you have the same problem i had.
Old Nov 17, 2005 | 09:12 AM
docholiday72tx's Avatar
docholiday72tx
Dizturbed, Pull out the guage panel and make sure the bulbs are good. While you have it out, look for a light blue wire with a red stripe. This is the wire that goes to accessory type stuff. If you keep blowing fuses....chances are good that wire has a bare place that is grounding out on something metal. Also, do you have an aftermarket stereo in your truck? If so, where is the hot wire with the key on hooked up to and where is the wire that is hot with the key off hooked up to? As far as the turn signals, check all the bulbs, the fuse, and the flasher first.
Doc
Old Nov 17, 2005 | 09:34 AM
73Custom's Avatar
73Custom
You have 3 different problems, that may or may not be related.
1. No blinkers. Do the brake lights work? Do the hazard lights work? Do the blinkers light up at all?
2. No dash lights. Did you twist the headlight ****? (this dims the dash lights) Are there lights for the heater controls or headlight/wiper switches?
3. No fuel guage. Does it move at all when key is turned on? Does the temp guage work? Often there's a problem with poor connections at the tank.
Marty
Old Nov 22, 2005 | 10:40 AM
dizturbed83
i now have blinkers but they work without turning the key on(hot all the time).i replaced the light switch and ignition switch and the fuse still is blowing(still trying to find a bare spot in the blue and red wire that goes for the dash lights).the fuel guage moves when i put a test light in the wiring harness under the hood.bad ground???thanks to all who replied.
