Sponsored by: Auxito
Day Time Running Lights
Old Nov 15, 2005 | 09:59 AM
ktown1965's Avatar
ktown1965
Will the DRL's work with only the relay (part#YL1Z-13B218-AA) plugged in that mounts on the top right side of the dash under the cover. I have the harness that this relay plugs into but do not have the harness for the resistor (part#1L3Z-14A601-AB) that mounts under/behind the left side headlight. The truck is a 2000 F150 7700 5.4L Lariat without fog lights. The question is, if I just use the relay will the DRL's work and if so will they work at 100% power?
