How Do I Remove Steering Wheel Play?
Old Nov 15, 2005 | 09:18 PM
7sixf150's Avatar
7sixf150
I had to that problem as well. I found it was the drag link. Works good now.
Old Nov 15, 2005 | 09:21 PM
tjs_79ford's Avatar
tjs_79ford
The first thing that I do when mine seems loose is inject grease on all joints on the tie rods and steering linkages. It seems to help a little bit.
Old Nov 15, 2005 | 09:31 PM
76supercab2's Avatar
76supercab2
Loosen the connectors for the rag joint. Loosen the steering column inside the cab, under the dash and at the firewall. Pull the steering column up to give you more room to work, then tighten the under dash bolts to hold the column up.
Old Nov 16, 2005 | 05:35 AM
scottlane's Avatar
scottlane
Thanks. Those were the tricks I was looking for. A real time saver to go afte those who have been there and done that.
texasjack
40
Jul 30, 2023 12:04 PM
sajin08
Jan 22, 2013 11:54 AM
darinbrooks
Dec 10, 2010 09:52 AM
kstiner
29
Nov 18, 2009 10:36 AM
Earl
Apr 17, 2000 04:49 AM
