I think I may still have a set of 352 heads and 2bbl intake for same. I'll take a look when I get home in a couple of days. E-mail me to remind me as I am kinda busy with a home improvement project and might forget.
Tim
I will not be rebuilding my 390 - and it was not knocking when I shut it down. I may have good heads, and should have a good 390 crank and rods. I will pull it down this week and let you know just what I have.
Why not see if what shortbed offered will do you? I am not sure just what happened to my 390 and will not know until I pull it. I would be worried about the heads.
I am in Olivehurst Ca. about 35 miles north of sac.
the 352 has never had the rod/main caps pulled so I have no idea what it looks like but it was running about 10 years ago when I replaced it with my 428.
the heads were pulled where it would fit under a shelf and out of the way.
I just looked at the heads up on the shelve, still there with 30+ years of grease on them...lol
I also have a stock 2 bbl and a stock 4 bbl intake.
all this is going to the dump soon, I need the room real bad.
I still have the intake that you gave me last year when I took the 4bbl intake off your hands... Its a truck intake with the big T on it. If you want it, I'll bring it over this weekend...for nothing.
