just got a99 stroker need power need advise
hi i just got my dream truck 99 psd supercab f250 superduty 4x4. i also just right now instaled a bully dog 4 bank chip woow dang the truck was alredy straight piped but i orderd a 5'' any way ialso ordered afe stage 2 air filter .is this sounding ok ? i want to add a mudule like an ez they say they can be stacked has any one done this . my goal is to smoke out as many dmaxxs as possable .
if you want to make smoke, i would recommend stacking a tuner and a fueling box. Edge's products are very compatible with one another. i would start out with the Edge Juice module with Attitude monitor, it has 5 different power levels you can change on the fly, plus the monitor has exhaust temp and boost pressure, which essentially eliminates the need for gauges if you dont want a transmission temp. once you have that, i would get the evolution programmer to stack on that. on the midto highest settings, you can blow a huge plume. i plan on getting the evolution so i can adjust my tranny and pull codes, but the power is a thing to boot.
talk to BuickTurbo, he has this setup.
thanks guys forgot to mention truck came with auto meter gauges trans pyro boost. can you tell me the paramaters to watch for gauges aint no good except for camp fie storys "the turbo muta been glowing 1800 f trans 500F cant remmber boost cause thats about the time it incenerated got out just in time but dang it sure was fast" thanks guys joining fte was the best thing i did for for my psd
Originally Posted by Fordafied
And when you want to graduate to some real power, get yourself a custom burned flip chip. No tuner out there will touch the power of a custom burned chip.
As far as gauges go, well if you don't want to have a meltdown, GET GAUGES.
Automatic transmission - 200* max, add another transmission oil cooler if need be.
Pyro / EGT (exhaust gas temp) - if the probe is installed pre-turbo, 1200* max, not sure if probe is post-turbo, too inaccurate. Most people like to keep it below 1100*, pre-turbo. The new intake and 4 or 5" exhaust will help keep the EGTs down.
Boost - I've read 30 psi is a good limit, and I've read 40 psi. At 40 psi it may literally "blow a gasket" or tear up the turbo. The right foot controls this.
Welcome to FTE. A great site with lots of info and helpful people. When you get a chance, fill out the signature info so others can see what kind of truck you have and what you've got on it.
LOL Now I'm doing moderator work.
i just instaled the bully dog in the back of the pcm high setting 150 HP is that what your talking about ? sounds like i should have joined up a little earler. thx again
Twildman is on this board and his name is just as I spelled it. You can PM him if you are interested.
One more thing, unless you have an over-boost eliminator, you will not be able to get the power due to de-fueling. That's when you boost to 22 psi and the truck will de-fuel to keep from going higher. The stock turbo is "rated" for 25 psi only. I have to Over-boost eliminator kit from ITP and it works great.
Hope this helps.
Originally Posted by PSNut
i agree on the Tipton burned chip...mines totally awesome!, not custom just an 80hp econo tune and WOW!
Originally Posted by johnny8
i have a similar setup as you... gonna get the exhaust system in the spring.. i hope.. then i think i will get a CUSTOM tuned chip from jt... we'll see... i'm very happy with the way my truck runs now though... i don't feel bad when i pull away from a ricer at a stoplight... the looks i get...!
I'm getting that tru-cool tranny cooler next. How has yours been? A cool tranny
is a happy tranny!
How does the custom chip work in everyday driving? I would like to get more power But I drive it everyday, But love to have lots of power when needed or wanted, and how will it effect fuel mileage when normal driving. I notice I lost a lot with my chip even when I am not getting on it, is it the same with the custom chip?
Thanks Derek
Thanks Derek
Yeah...i pulled away from a riceer at the Bedford Toll...lots of fun!
is a happy tranny!
is a happy tranny!
