Offroad & 4x4
Bronco help
Old Nov 14, 2005 | 11:11 PM
xpeacen0tgreedx's Avatar
xpeacen0tgreedx
Bronco help
hey, i have a 96 bronco today i was in 4wd and i pushed the button to take off 4wd then later backed up like 20 feet to disange the hubs but still i get a whining sound when i drive in 2WD that seems to be coming from the front hubs
what is the sound and what should i do to make the sound stop??
Old Nov 14, 2005 | 11:34 PM
fishmanndotcom's Avatar
fishmanndotcom
those crappy auto hubs. you can try and pull'em apart and clean'em but they prolly dont have long till they are trash. do NOT pack them with grease when re-installing, a light coat is plenty. just replace them with manuals and be done with it for good.
-cutts-
Old Nov 15, 2005 | 12:17 AM
xpeacen0tgreedx
thanks... how much do they run for/ is there ne thing else i can do to fix em?
Old Nov 15, 2005 | 04:24 PM
fishmanndotcom
prolly looking at somewhere around $100, just depends on where you go
you're best bet is to just replace them
-cutts-
Old Nov 15, 2005 | 05:21 PM
chrono4's Avatar
chrono4
like said, the auto hubs tend to stick and whatnot, just replace them, cause when you need 4wd the most, it wont be there.
Old Nov 15, 2005 | 06:53 PM
bronco351's Avatar
bronco351
Before you go and start throwing new hubs on the truck, make sure the transfer case motor is turning it back to 2wd. Just drive the truck in a tight circle and see if the 4x4 is still on, if it is, time for a new t-case motor. Theyre cheap, only about $25 at a junkyard.
Good luck!!!
Bronco Buddy
1978 - 1996 Big Bronco
Dec 16, 2020 12:47 PM
alta825
Offroad & 4x4
Aug 21, 2007 07:13 PM
bud1963
Bronco II
Sep 7, 2005 09:04 PM
fast_eddy
22
Dec 25, 2001 02:48 AM
