what is this worth
Old Nov 14, 2005 | 08:30 PM
monster76's Avatar
monster76
what is this worth
edelbrock cross ram intake for fe block has a part number on it xf66 or something like that i am wondering what its worth
Old Nov 14, 2005 | 09:15 PM
gtex's Avatar
gtex
Check ebay. they go up there occasionally. I suspect it's worth about $500 in good useable shape.
Old Nov 15, 2005 | 04:56 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
I have seen the FE CrossRam go for anywhere between $400 to $850 depending on condition...and the complete set-up with Carbs and linkage for $1600... I know one Guy right now that has one with Carbs for $650 but the carbs need a rebuild, and the Intake needs to be media blasted...
Russ
Old Nov 15, 2005 | 06:56 PM
monster76's Avatar
monster76
wow i made a good purchase i bought it at a garage sale for $50 i hot tanked it and blasted it already my neighbor works at a machine shop, if i were to put this on a 390 with ported heads and a +.030 bore what kind of carbs should i run i was thinking two holley 350 cfm carbs
Old Nov 15, 2005 | 07:26 PM
gtex's Avatar
gtex
From what I've read here, you're better off with two carbs just smaller than what you would run for a single. So, for a hot 390 where a single 750 would be good, you'd want to run a pair of 600s. I know it sounds crazy, but it appears to be the norm.
Sounds like you got a steal. You'll need some good flowing heads, high compression ratio, headers/duals , and a big cam to make it all work well.
Old Nov 15, 2005 | 07:38 PM
RapidRuss's Avatar
RapidRuss
Well depending on port work on the heads,choosen Cam, you could run a set of 600 holleys a mentioned buy greg, Or if you run a wild Cam you could step up to 650's...
Hell depending on the head flow and cam you could probably get away with a set of 550's
JMO....
And by the wat congrats on the score of the crossram!!!
Russ
Old Nov 15, 2005 | 07:43 PM
fordraceboy's Avatar
fordraceboy
i'll give ya 75 for it sight unseen.. LMAO
Nice score!!!
Old Nov 15, 2005 | 11:08 PM
gtex's Avatar
gtex
I'll go $76 :-)
Old Nov 16, 2005 | 12:09 AM
fordraceboy
the first bidder never has a chance... lol
Old Nov 16, 2005 | 12:22 AM
gtex's Avatar
gtex
even if by some miracle, he sold it to me for $76, it would still end up costing me thousands :-) That "Might as well" mentality would take over. Might as well get those heads ported while the intake is off, probably ought to upgrade to that 541 roller cam and of course I'd need another BG SPeed Demon 750 Carb :-)
It' a sickness.
Old Nov 16, 2005 | 12:44 PM
fordraceboy
if i'm gonna run two carbs i may as well by a tunnel ram... if i'm gonna buy a tunnel ram i should just buck up and get a 8-71.... oops almost forgot, now i need a second NOS kit for the other carb.. better get another fuel pump so i don't starve the motor... LMAO
I don't know if i'd call it a sickness cuz you can usually cure a sickness, better call it a disease!!! LOL
Old Nov 16, 2005 | 02:47 PM
Scouder's Avatar
Scouder
Originally Posted by gtex
That "Might as well" mentality would take over...
It' a sickness.
6 years and counting for me. And by "counting" I mean years and dollars!
If you ever see a post claiming that my project is finished you'll know right away that it's an imposter.
-Scouder
Old Nov 16, 2005 | 02:55 PM
fordraceboy
and the dollars always match the years... exponentially of course!!! LMAO
