uh-oh....
Old Nov 14, 2005 | 08:05 PM
p521us's Avatar
p521us
Question uh-oh....
Ok this is kind of hard to explain but about 3 months ago I installed a new stereo in my 93 f-150 and I am now having problems with the battery and all things electronic. When I flash my bright lights everything gets reset like the radio, gauges, and that’s about all the electronics on it... and another problem is it intermitaly wont start due to the lack of power. I checked and re-checked the battery and alternator and they are working just fine. My dad thinks its something in the ignition, if the key is out you can sometimes start it. Me and my dad are out of ideas so I thought id throw it to you guys. Sorry for the grammatical errors and such.
Old Nov 14, 2005 | 08:27 PM
handyman43358's Avatar
handyman43358
Hmmmm sounds like a problem my buddy had/still has. He put a new stereo in, and when you open the passenger door, the cd player pauses. The only way to unpause it is to hit the button to roll down the driver side window. Freaky stuff. Sorry this wasnt helpful, but at least you arent the only one with problems like that lol.
Old Nov 15, 2005 | 07:20 AM
low92flareside's Avatar
low92flareside
Check your positive battery cable at the battery terminal real good. I'm not a big fan of Ford battery cables and these problems sound similar to those that I have experienced.
Old Nov 15, 2005 | 08:32 AM
whiteyfordzx5's Avatar
whiteyfordzx5
first of all, read here:
https://www.ford-trucks.com/forums/s...d.php?t=399714
second, how did you install the head unit? did you use an adpater harness, or splice it in?
Mike
Old Nov 15, 2005 | 09:25 AM
pfogle's Avatar
pfogle
It sounds to me like you hooked the ground to the illumination wire. This is a common mistake as it is a ground until you turn on the headlights.
Old Nov 15, 2005 | 02:27 PM
racedude48's Avatar
racedude48
Also check that you dont have a coil of extra wire near your harness. It will creat and electromagnetic field around the coil of wire and screw with the wires around it. Alot of dodges had these problems.
Old Nov 15, 2005 | 05:25 PM
p521us's Avatar
p521us
low92flareside: i re-wired the cable so check that off the list.
whiteyfordzx5: my bad i havent been her in a while , and no splicing.
racedude48: no dangling wires used 'em all
handyman43358: had your bud done anything about it or does he just live woth it?
Old Nov 15, 2005 | 05:49 PM
alabamabuddog's Avatar
alabamabuddog
Sounds like your dimmer switch to me.
Old Nov 15, 2005 | 06:59 PM
handyman43358
I think he has just learned to live with it honestly. I havent talked to him for a while. His truck is all messed up wire wise. The reverse lights are on all the time, but go out when the brakes are applied lol.
Old Nov 19, 2005 | 05:13 PM
McLeod's Avatar
McLeod
I had a similar problem. Radio would keep playing after turning key off. You had to press the power window button and then the radio would turn off.
After a month of this, the radio also started turning on all by itself (usually at 3 am when all are asleep).
The problem: wires in main harness that were fused together. I took the cheap fix of jumpering the short.
All good now.
Old Nov 19, 2005 | 07:43 PM
tomandbeth's Avatar
tomandbeth
I thought that was a "feature" of Dodge's in general. ;-))))
Old Nov 19, 2005 | 09:48 PM
bondjamesbond's Avatar
bondjamesbond
my cruise cancels when I use my left turn signal, same thing maybe
Old Nov 20, 2005 | 12:50 PM
p521us's Avatar
p521us
I figured it out. It was the selonid on the front finder pannel, by the battery. I dont know how it broke i just replaced it like 3 months ago....
Old Nov 20, 2005 | 04:43 PM
chrono4's Avatar
chrono4
what was broke on it? was is a terminal or what?
old broke prospector
Apr 9, 2013 07:43 AM
wingnutt2420
Sep 22, 2011 04:10 PM
PaulzF150
Nov 20, 2009 08:48 PM
dani9678
Sep 22, 2004 07:20 PM
matock
Mar 18, 2001 04:27 PM
