Speedometer drive gear
Old Nov 14, 2005 | 11:58 AM
Steve's Avatar
Steve
Does anyone know the tooth count on the speedomter drive gear in the '56 three speed lght duty tranny? I am trying to calculate the correct number of teeth on the driven gear I need.
Thnaks guys-
Steve
Old Nov 14, 2005 | 06:33 PM
barry's Avatar
barry
There's a few different ones depending on rear end ratio and the tire size you have on your truck. List these and I can look it up.
Barry
50 F-1
Old Nov 14, 2005 | 06:38 PM
Steve's Avatar
Steve
Barry-
1956 long bed F-100
Engine 292
axle 3.73:1
Trans light duty column shift 3 speed.
235-75/15 Tire diameter = about 28.5 Inches
Exisiting speedo driven gear has 20 teeth, and speedometer seems to indicate about 5 mph slower than actual.
Steve
Old Nov 14, 2005 | 07:40 PM
barry's Avatar
barry
You should have 8 teeth on the driving gear on the tranny output shaft. Your driven gear is the one that makes the difference. It appears you should have a 21 tooth driven gear for 6.50x16 tires or 22 for 6.00x16 inches tires. For 56, there's a 7.10x15 listed, that uses a 19 tooth gear. You're going to have to experiment with the 3 different gears to get a close reading. Being you have modern tires on it, your readings will be slightly off.
Barry
50 F-1
Old Nov 14, 2005 | 09:10 PM
hiball3985's Avatar
hiball3985
Barry..just for my curiosity, how do you count teeth on a worm gear(drive gear)???
Old Nov 15, 2005 | 11:21 AM
barry's Avatar
barry
That's a good question. I just rely on my parts book for the correct ones. I suppose you could count the high spots.
Barry
50 F-1
Old Nov 15, 2005 | 12:43 PM
hiball3985's Avatar
hiball3985
thanks Barry, I only had to change one to get the speedo corrected after changing driven gears didn't work, I remember the one I changed was a differrent color, so I am asuming they are color coded, I know it had what seemed to be more teeth, but I couldn't find a way to count them..LOL
Old Nov 15, 2005 | 01:14 PM
Steve's Avatar
Steve
Well in the interest of simplifying things, since my speedo reads 5 to 10 mph slow, I went ahead and ordered the 19 tooth driven gear to replace my existing 20 tooth. Not very scientific, but I'll report the result, and then we'll know.
Old Nov 15, 2005 | 01:17 PM
hiball3985's Avatar
hiball3985
that will probaly do it.........good luck
Old Nov 15, 2005 | 03:14 PM
Christopher2's Avatar
Christopher2
Veteran: Navy
One tooth out of 20 would be a 5 percent reduction in the number of teeth.
Blackduck59
Dec 4, 2012 04:43 AM
eldon
Nov 27, 2006 05:45 PM
roundss
Nov 11, 2006 09:43 AM
Steve Barker
Dec 3, 2004 07:57 PM
