1978 - 1996 Big Bronco
Front rotor replacement
Old Nov 14, 2005 | 10:04 AM
Chad Winship's Avatar
Chad Winship
Hey guys sorry for the duplicate post. I've seen alot of discussion and frankly it went over my head so I wanted to see if you all could simplify it for me.
93 Full size XLT with 32 x11.50's still has the auto lockers on the front. I need to replace a front rotor.
Do I really have to dissassemble the whole front hub to get the rotor off, that whole 4 tab spanner wrench on the inner lock nuts, take out the bearings etc etc etc?
Or if I take the auto locker assembly out will a wide jaw puller pop that outer hub housing off without disturbing the inner hub stuff.
Oh and yeah, if I get to this I WILL be replacing the auto's with Warn premiums or Mile marker manuals, I'll do some searching on who reccomends what on THAT situation seperately. ;-)
Old Nov 14, 2005 | 10:45 AM
BillyBob69's Avatar
BillyBob69
Buy the Warns and start disassembling. You do have to take apart the hub to pull the rotor. Also, You will need to seperate the hub from the rotor once you have it off. But, you can also buy the hub/rotor assembly and not have to seperate the old ones. I did this with my 85 and it was an easy swap. Cost me about $70 each side.
Old Nov 14, 2005 | 11:19 AM
Chad Winship
Thanks.
Crap.
Is it just me or does it seem to anyone else that they could have done that a better way? Rotors wear out far faster than anything else, why not design it so it can come off more easily? GRRR.
Old Nov 14, 2005 | 11:42 AM
BillyBob69's Avatar
BillyBob69
They can be seperated easily......If you have the right tools. I just prefered not to bother with it. Since you have it apart, why not new bearings and seals too.
Old Nov 14, 2005 | 03:17 PM
RA81222's Avatar
RA81222
rotor tone ring removal
What's the best way to remove antilock ring from hub abd rotor assy?
Old Nov 14, 2005 | 04:42 PM
DARK_HORSE's Avatar
DARK_HORSE
I used a 3 jaw gear puller to remove mine.
Old Nov 14, 2005 | 07:52 PM
Blue'87GT's Avatar
Blue'87GT
I just tapped the lugs out slowly and evenly and it came off without breaking. Tapped it back on with a hammer as well.
Old Nov 14, 2005 | 11:11 PM
rudder9's Avatar
rudder9
I did mine on my 95 awhile back. After 10 years, my abs rings did not want to come off easily.I asked my mech. friend and he said use a torch.A little heating and tapping on the studs and off thay came.I raplaced my rotors with x- drilled powerstop.What a difference,and while I had everything apart anyway, I did my ball joints,with good h-d ones.
