Torque settings?
Old Mar 19, 2002 | 11:02 PM
gr8199's Avatar
gr8199
Torque settings?
I'm looking for the tightening procedures for the tie rod, drag link, and center link nuts.
I replaced these items and I can't find the specs to tighten them properly.
I Only snugged them to line up the cotter pin hole so far.
I measured the old linkage and adjusted the new one the same.
I just want to be safe when I drive it to the alignment shop.
Thanks,
Don
1973 F250 3/4 ton Custom
390 .060 over w/428 inside (422?)
Edelbrock Performer intake
Holley 4160 carb
14" K&N Filter
True Dual Exhaust
and more to come.
Old Mar 20, 2002 | 08:20 PM
sparky's Avatar
sparky
Torque settings?
Ok I dont know the torque but since it is a castelated nut with a split pin, the bottom of the bolt hole should line up with the bottom of a castelation in the nut. As long as you have the proper nut. I will take a wild guess and say 50-60 ft/lbs should seat it correctly. Of course that value depends on the nut and bolt thread condition, how accurate your torque wrench is and how close my guess is
Anyhow that will get you safely to the alignment shop and they should know the right torque.
Better yet give then a call and ask them what the torque is before you go.
Sparky
Old Mar 20, 2002 | 09:39 PM
gr8199's Avatar
gr8199
Torque settings?
Thanks Sparky,
I got the same 50-55 number elsewhere.
I torqued them at 50# with my Snap-On wrench and then tightened them until the cotter pin hole lined up.
Don
Holley 4160 carb
14" K&N Filter
True Dual Exhaust
and more to come.
Old Mar 20, 2002 | 10:24 PM
fastfrank's Avatar
fastfrank
Torque settings?
