Sponsored by: Real Truck
Headlight problems
Old Nov 12, 2005 | 11:39 PM
mx920cj's Avatar
mx920cj
Headlight problems
Anyone ever had a problem with there headlights not coming on? Mine sometimes will not come on, and it dosen't matter weather they are set to come on auto. or manual. If they won't come on, sometimes I can turn my truck off, wait a few minutes, start it again and then they will come on. If not I have to drive while manually holding the bright lights on, because the bright lights won't stay on by themselves if I can't get the regular headlights to come on. Hopefully all that made sense, and if anyone has any suggestions please help. Thanks, Chad
Old Nov 13, 2005 | 06:23 PM
mx920cj's Avatar
mx920cj
Anyone have any ideas? Thanks
Old Nov 13, 2005 | 08:47 PM
BFR250SD's Avatar
BFR250SD
Sounds like the switch may be bad or have a loose connection. Pop the switch out and see if everything is connected right and the harness is plugged in fully. Only other thing is maybe a bad ground, but from what you are describing, I would start at the switch.
Old Nov 13, 2005 | 09:09 PM
mx920cj's Avatar
mx920cj
Thanks for the help!
Spitfire372
Jan 1, 2014 12:37 PM
Emmymau
1983 - 2012 Ranger & B-Series
Aug 27, 2010 07:33 PM
huskermark764
1997 - 2003 F150
Dec 6, 2008 12:18 PM
snagmaster86
Sep 13, 2006 07:28 AM
mike2002
Dec 27, 2005 06:51 PM
