Pcv Valve Location
Old Nov 12, 2005 | 10:11 PM
justin_galens's Avatar
justin_galens
Pcv Valve Location
got a 93 F150, manual shows location for a carberated engine, mine is EFI, where is the PCV Valve located on a 4.9L?
Old Nov 12, 2005 | 11:08 PM
ATC_250SX's Avatar
ATC_250SX
top of the valve cover, front or rear, there is only two lines, the one with a plastic elbo that rattles, and looks like it has something plugging it inside is your pcv valve.
Old Nov 20, 2005 | 10:08 PM
justin_galens
thank you for the reply on the valve. sry tok a bit to rply. found it though. any idea why truck would have a rattle in either engine or tranny after doing a simple oil change?
Old Nov 25, 2005 | 10:07 PM
ATC_250SX's Avatar
ATC_250SX
Did you forget oil??? and is it all the time or just at startup?
suppose it coulda ruined a bearing or something if it took a long time to get lubed
chuck7300
Sep 6, 2008 02:38 PM
BAJI26
Mar 16, 2008 01:24 PM
randy6800
1983 - 2012 Ranger & B-Series
Mar 13, 2008 07:06 PM
rth1
Mar 9, 2005 02:21 PM
vsp160
Mar 14, 2004 02:25 PM
