Help with C bushings
Old Nov 12, 2005 | 06:57 PM
yeha4x4's Avatar
yeha4x4
Hi everyone, I am trying to put a 4" lift on my 76 f150 4x4 and can't seem to squeeze the bushings enough to get the cap on. the new bushings are 7 degree and seem much thicker than what I took off. I spent about a hour trying to put on one side. I was thinking off buying some longer bolts so I can pull the two halfs together and then install the correct ones. Has anyone else had a hard time putting them on??
Old Nov 12, 2005 | 07:04 PM
MBBFord's Avatar
MBBFord
I just pushed them in place as much as possible then put the two parts of the radius arms together and I could just get the threads to catch and then I tightend them up alternating corners.
Old Nov 12, 2005 | 07:16 PM
yeha4x4's Avatar
yeha4x4
I will try again in the morning.
Old Nov 13, 2005 | 12:43 PM
yeha4x4's Avatar
yeha4x4
5 hours of work later and one side is done. Time to give it a break
Old Nov 13, 2005 | 01:07 PM
MBBFord's Avatar
MBBFord
Man, I fell sorry for you, there must of been some serious space between those bushings. It took me a hour to do mine(both), and I thought that was long.
Old Nov 13, 2005 | 06:07 PM
yeha4x4's Avatar
yeha4x4
I ended up buying two longer bolts and using them to pull the cap on far enough to start the original ones. I only needed the bolts to be about 1/8 longer. the other side should take about an hour. MBB when you replaced them did use stock size or the thick Daystar poly units which I have??
Old Nov 13, 2005 | 06:58 PM
MBBFord's Avatar
MBBFord
I belive it was daystar, and yes it was poly 7 degree buchings.
Once I squezed and gigled it a little I had about 1/8" thread that I could use.
Old Nov 13, 2005 | 08:02 PM
yeha4x4's Avatar
yeha4x4
That makes me wonder what the deal is with mine? i wonder if it would have made a diff if I would have taken both sides completely apart so I could have moved the front axle easier. I just jacked the truck up high and put jack stands under the frame and put a floor jack under the axle, then took out the coil, pulled the radius arm and put new bushings on the end that attaches to the frame and slid that back in and thats where my problems getting the C bushings in started. Front bottom does mean pointed towards the radiator with the word bottom towards the ground, because I did notice if I would have put them in backwards I could have put the cap on.
