Water Hammer
Old Nov 12, 2005 | 03:38 PM
B. Abel's Avatar
B. Abel
Water Hammer
This is a first for me,1991 Explorer XLT, I'm Getting water hammer in the cooling system.
If the engine is cold and I run 2 or 3 miles and then shut it down I get a recurring thump from the heater area under the dash if I restart the engine it stops, if the temp is right up it doesn't do it and now my rad is weeping about a pint of coolant a day around the tank edge (fill side)
has anyone had this problem and whats the fix?
Thanks
Old Nov 12, 2005 | 05:36 PM
alchymist's Avatar
alchymist
"Mifflin Clay"
Just a wild guess - you might have a head gasket leak, just enough to get combustion gasses in the cooling system, building up pressure...... Try taking the radiator cap off when cold, start it, and watch for bubbles in the fluid. Let it warm to operating temp.
Old Nov 12, 2005 | 07:10 PM
B. Abel's Avatar
B. Abel
Thanks but I've redone the heads had them checked (magnafluxed and pressure tested) and put new headgaskets in myself (so I know they are right) I didn't have a problem till I replaced the rad. And it hasn't gotten anywhere near overheated since I've done the headwork.
Headwork done a year ago, Rad replaced 2months ago.
Old Nov 12, 2005 | 07:22 PM
Ultramagdan's Avatar
Ultramagdan
Are your hoses in good condition? That's a pretty hard hammer to have your rad already weeping.
Old Nov 12, 2005 | 09:14 PM
B. Abel's Avatar
B. Abel
yes new hoses and heater core.
Old Nov 12, 2005 | 09:50 PM
Ultramagdan
Bleed the system. Put it up on blocks and leave the cap off, cycle the heater while doing doing so. Sounds like the only thing you haven't replace is the water pump.
tigertail222
1997 - 2003 F150
Feb 20, 2011 09:27 PM
Duke78
Paint & Bodywork
Feb 17, 2008 06:41 PM
djmac
Nov 23, 2006 11:43 PM
xavierarmadillo
1983 - 2012 Ranger & B-Series
Jan 23, 2006 11:42 AM
LongHorse
Sep 22, 2004 09:55 PM
