Do people even do this anymore? I was just wondering how practical it is. I bought a 71 and the original engine has been out for several years. I don't think it will be able to be dropped in as-is judging by what I have found (blown out freeze plugs). Block could very well be junk.
My goal was a decent running small block, no drag racing, stump pulling, or trailer towing. Of course, money is a factor. Not wanting to cheap out, or break the bank.
I have been thinking about my options, finding a running motor, trying to rebuild the original 302, rebuild a 289 I have laying around, or a crate motor. I originally planned on a 302 and a 4V carb. Lately been thinking about EFI. I have read several articles (online & magazines) about adding the Mustang EFI to older motors. Results "seem" decent. But it seems like to get the most out of the EFI (torque & mpg), a roller cam is required. If adding a roller cam to an older block, is it any better or cheaper than just starting with the HO long block? Seems like it wouldn't be.
Far cheaper to start with a roller block. Don't need an HO for that. All the late 80's to the end of production in 2001 5.0's were roller blocks. 351's were starting in 94. Converting a non roller block will set you back around $500 ( minimum)
It depends on how you do it. If you buy all aftermarket roller stuff with tiebar lifters it gets pretty pricey in a hurry. If you do some scrounging (like on Ebay, etc.) you can get stock Ford late model roller lifters, dogbones and spider and a retrofit kit to install it in a non-roller block. Since you need to have the lifters sit further down in the bore, a special smaller base-circle cam is required, and I believe the choices of grinds are still pretty limited. With roller cams, you can re-use used lifters on a new cam so you might save some bucks with used parts. If you're lucky, you might come in within a few hundred bucks or so. Check out these threads on the subject:
Even with scrouging for used parts, you're still facing the cost of the reduced base cam ( $300+), & new custom pushrods ($100) No matter which route you choose, it's not worth the cost. The other route uses Crane's link bar lifters($400+) for this and std base cams ($100+) And possibly custom pushrods as well. There's just no "cheap" way out of this, unless someone gives you all the parts.
