Which engine paint?
Old Mar 21, 2002 | 07:32 AM
Blaine's Avatar
Blaine
Which engine paint?
I have to replace the intake gasket on my 302 and thought I would give the manifold a spruce up while I had it off. Need recommendations on a good high heat paint (Ford blue matching of course) that would last. Is there a primerless paint for example?. I thought of those NAPA spray bombs but it is not clear if they would stand up well to the heat
thanks
Old Mar 21, 2002 | 08:31 AM
KJKozak2's Avatar
KJKozak2
Which engine paint?
I just repainted my oil pan, air filter, and valve covers with plasti-cote high temp engine enamal. It says it "resist heat up to 500 deg" and I haven't had a problem with it yet. It comes in all the standard automotive colors (Ford Blue, Old Ford Blue, GM orange, etc...). It's also supposed to stand up well to automotive fluids/oils. It was only a few bucks a can and I believe you get what you pay for. So some of the pro paint guys here may have a better solution.
Keivn K.
Old Mar 21, 2002 | 08:37 AM
Blaine's Avatar
Blaine
Which engine paint?
I assume that is available in major auto parts retailers? Cant say I have seen it.
thanks
Old Mar 21, 2002 | 10:40 AM
beartracks's Avatar
beartracks
Which engine paint?
The key would be to get the part really clean. Sand blast lightly if possible or at least scrub with stiff brush and good cleaner. The spray bombs work pretty good actually. Krylon or Plasticoat. That what my machine shop uses for all it's engines.
Bear Tracks
Old Mar 24, 2002 | 01:10 AM
77460ford's Avatar
77460ford
Post Which engine paint?
POR-15 also makes a nice engine enamel that they guarantee will not burn off. I'm just painting up a water pump and heads now but if it works as well as their paint I used on my frame then it should be great.
Old Mar 25, 2002 | 12:47 AM
masterbeavis's Avatar
masterbeavis
Which engine paint?
Old Mar 25, 2002 | 12:54 AM
masterbeavis
Which engine paint?
The 500 degree spray bomb stuff will burn off around the exaust area of the heads, but otherwise will do what it is supposed to. The POR is more expensive, but the next motor I do, I will pony up the $$$ for it.
Tony
'74 F250. 460, "beater"
'73 F250, "midnight auto" now a trailer
'77 F250, 460 transplantee, "Flamer"
98powerstang
Paint & Bodywork
Dec 7, 2012 08:05 PM
56panelford
Jul 5, 2011 09:03 PM
dotcentral
Paint & Bodywork
Apr 9, 2005 11:25 PM
78-f150-4x4-351m
General Automotive Discussion
Mar 6, 2005 09:44 PM
Dieseldan7.3
Paint & Bodywork
Nov 23, 2004 10:01 PM
