Tire Pressure
Old Nov 11, 2005 | 10:29 PM
NightHawk150's Avatar
NightHawk150
Tire Pressure
Does anyone know if it is normal for the the tire presurre to come on almost everytime i start the vehicle. I ask because when i got it, it came with these little things where you put the air in, you know, the ones where if it's green it's ok and if it's red it needs air and what not. So anyway, the little tire pressure thingys say that it's ok (green) yet, every time i turn the Expedition on, it says tire pressure low and the light comes on also, however, after a while of use, the light comes off. I was just wondering if the tire just needed to warm-up or something. Well, thanks in advance.
Old Nov 12, 2005 | 12:18 AM
Monsta's Avatar
Monsta
Sit. Stay.
What is the cold tire pressure?
You might want to check it before you start it just to see if it is out of range (low)...regardless of what those indicator caps say.
Old Nov 12, 2005 | 12:27 AM
ford390gashog's Avatar
ford390gashog
those caps are not reliable to base your tire pressure off of. the ford system is very reliable. so it is obvious you have low tire pressure.
mebe2k
6.7L Power Stroke Diesel
33
Nov 15, 2015 10:56 AM
wrxin
May 21, 2014 09:17 PM
itry2fly
Jan 10, 2013 07:29 PM
xjcamaro89
2004 - 2008 F150
Nov 24, 2008 08:13 AM
Lane Dexter
Dec 7, 2006 06:28 PM
