Intercooler boot blew off!
Old Nov 11, 2005 | 05:14 AM
RushN350's Avatar
RushN350
I was driving to work this morning around 70mph and BOOM, it sounded like I ran over somthing and it hit the bottom of my truck. When I got to work I saw the return intercooler pipe blew out of the boot. Anyone know what might cause this besides a loose boot? (they were all really tight after w/w install).
Old Nov 11, 2005 | 05:58 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
maybe you over torqued them. somewhere on the boot it says to not overtighten. did you clean all the boots with acetone or similar when they were out? if you dont have the CCV mod done, there is your culprit. the crank case vents oil mist into the vaccuum of the intake air boot. the oil mist goes through the turbo charger, and through all of the intake piping. it leaves a oily film on all of the parts. some people even have had oil in their intercooler. your boot was probably lubed up enough that it just popped off at a high boost level.
check my gallery, i have pics of my ccv mod that i did, it only cost about $8 for the piece of hose. i had the superglue and the bung to tie it in my exhaust already.
Old Nov 11, 2005 | 06:14 AM
Fordafied's Avatar
Fordafied
AAHHH, the old boom! It has happened to quite a few folks. The oily residue around the boots is probably the culprit. Make sure you clean the mating surfaces real good before putting them back together, that is the key.
Old Nov 11, 2005 | 06:23 AM
Orezona's Avatar
Orezona
So if I don't have the CCV mod, cleaning the boots should probably be a once a year maint. thing right?
Old Nov 11, 2005 | 06:24 AM
Fordafied's Avatar
Fordafied
Wouldn't hurt to do it once a year.
Old Nov 11, 2005 | 06:29 AM
RushN350's Avatar
RushN350
Thanks
Yes, I did clean the boots real good before renstalling, and also yes there was oil in both intercooler tubes, boots, 5-way, and into the intake ports (orange boots). I was considering the ccv mod but now I'm gonna go for it!
Thanks for the replys.
Old Nov 11, 2005 | 06:48 AM
RushN350's Avatar
RushN350
That brings me to another question while i'm at it. With all that oil in the system, that would lead me to believe that the intercooler is quite oily also. Is there any know way to clean them out?
Old Nov 11, 2005 | 07:04 AM
Kwikkordead's Avatar
Kwikkordead
Take it off the truck and lay it face down. Fill it with a solution of detergent and water. Agitate. Dump out. Repeat until all the oil is removed. Rince until clear.
Big project. I haven't gotten around to doing mine yet either.
Old Nov 11, 2005 | 07:17 AM
RushN350's Avatar
RushN350
Thanks kwikk!
Old Nov 11, 2005 | 07:21 AM
PowerstrokeJunkie
alot of people who have done this never get alot oil out of it.
Old Nov 11, 2005 | 07:26 AM
Kwikkordead
So it doesn't really work, or there wasn't much to begin with?
Old Nov 11, 2005 | 07:48 AM
RAMPAGE_F350's Avatar
RAMPAGE_F350
I seem to recall in another thread someone taking the intercooler to a radiator shop and having it boiled. To get the subborn gelled oil out.
Old Nov 11, 2005 | 08:21 AM
Fordafied's Avatar
Fordafied
I have also read where others have cleaned it in different manners and did not get much out. MHO it is not worth pulling just for a cleaning. After I did my CCV mod, I do not get any more oily residue on the boots.
Old Nov 11, 2005 | 08:42 AM
4X4 IN REFUGIO's Avatar
4X4 IN REFUGIO
If You Decide Not To Do The Ccv Mod ( I Have Not But Should ) Then At Least Reclean All Of The Connections To Remove All The Oil Film And Then Spray The Connections With Hairspray. This Should Help Them From Slipping Off Again. This Is What I Did And Have Not Blew A Boot Since. I Have Checked Them Periodically And Have Not Noticed Any Sighs Of Slippage.
Good Luck,
Doug
