daully convert
Old Nov 10, 2005 | 11:22 PM
devilsword's Avatar
devilsword
Lightbulb daully convert
i was thinking about doing a daully converstion on my 87 ranger 2.9 2wd. i thought i would be the only one who has done it and if i don't get a post for help i geuss i am but..... has anyone had in coplications with this type of conversion? i am not doing a compleat Axle but i know someone who will build adapters for me that will alow me to basicly bolt on 2 sets of tires to the axle. but will i need to change gear ration or any like that or what? anyone? my truck is lowered a lil i dont know if that makes a difference? good luck
Old Nov 11, 2005 | 08:11 AM
Tiggie's Avatar
Tiggie
I have see it done before using the JC Whitney part, check it out at jcwhitney.com. They are part number ZX786951NF. I don't see why you would need to change the axle ratio, unless you plan on going with larger tires. Even then it's not manditory. I wouldn't look to be hauling additional loads with it, I think this type of conversion is only for looks.
They recommend part number ZX786952TF, which is Extension Bolts for the dually adapter.
If your truck is lowered too much, your probably going to have to do some cutting to the wheel arch.
Old Nov 11, 2005 | 11:36 PM
devilsword's Avatar
devilsword
well its not lowerd to the point that i cut the bed. but i am ruing adjustible air shcoks to worse comes to worse i can cut the finder and increase the psi.
Old Nov 12, 2005 | 08:52 AM
RangerPilot's Avatar
RangerPilot
You shouldn't need to. If you use the same size wheels for all four, which you will, and the stock ones fit under there, they all four should fit just fine.
Old Nov 12, 2005 | 09:05 AM
BinaryWhisper's Avatar
BinaryWhisper
hi, I have a 1990 with the dually conversion.
Nothing wrong with doing it but it is a visual package only, it is not a good way to increase your payload regardless of what anyone claims. If you use it as a method of increasing payload you will simply wear out your wheel bearings and prehaps your axles as well. I run mine with 32 lbs air pressure on the inside wheels and 20lbs on the out side in an attempt to minimize the pressure exerted on the bearings. Real dually's have 2 sets of wheel bearings per side
JC Witney will sell the adaptor, extended lugs, extended air fillers, and or the fenders as a pack or seperately.
I was thinking that down the road I will build a 5 liter Ranger conversion and install the fenders to cover a nice set of 50's on the back.
Mine has got a load of parts on it including a wicked set of custom build running boards. They are built out of aluminum checker plate and form a vert tight fitting wedge from the front fender to the extended rear fenders. Has a Lund visor, wicked chrome tube bed rails, tonneau cover, billet grill. The truck is in real nice shape inside and out, paint is decent and it looks real good.
Old Nov 12, 2005 | 09:16 AM
BinaryWhisper
oh, the lowering shouldn't make any difference at all. You have to cut a big section out of your rear wheel wells to install the duallys anyway so the lowering simply means cutting a bigger section out.
As for the gear ration. No reason to change it but when you add that much mass to the drive wheels it will eat up some horsepower. Probably a noticeable amount. Its the same principle that eats horsepower when you switch to larger diameter tires and rims. It can add up to a surprising reduction. I remember an issue of Two Guys Garage on TV and they lost, I beleive it was 7 or 8 hp at the wheels just by going up a couple of inches in rim size. They happen to have a dyno so they were aware of it, most people don't seem to realize.
