what brand injection pump
Old Nov 10, 2005 | 07:57 PM
ger32's Avatar
ger32
What brand injection pump does an E350 with a 7.3L diesel engine have?
Does it also have an auxilliary lift pump?
Old Nov 10, 2005 | 08:58 PM
Dave Sponaugle's Avatar
Dave Sponaugle
What year is the van?
Old Nov 11, 2005 | 05:54 PM
ger32's Avatar
ger32
1989 24ft Vanguard motorhome on a 1988, I would assume a 1988 because, I am told, usually motorhome manufacturers buy chassis of the previous year
Old Nov 14, 2005 | 02:13 AM
ger32's Avatar
ger32
Old Nov 14, 2005 | 06:57 PM
Dave Sponaugle
Stanadyne is the manufacturer.
Old Nov 15, 2005 | 06:26 AM
bilder12's Avatar
bilder12
the injection pump is a stanadyne db2 for the international engine. I believe stanadyne also made the same style pump for the (gulp) chevy diesel. the engine does need an aux lift pump that is camshaft driven like a gas engine. this lift pump provides about 7 psi if fuel pressure to the injection pump. if there are 2 fuel tanks, there is probably a switch to select individual tanks mounted along the inner frame rail. you want to make sure the fuel filter is full upon installation. the engine has a glow plug system to provide heat to the precombustion chambers to aid in starting. are you having problems starting ? Also, dont crank on the starter too long at any one time, they overheat in a hurry.
Old Nov 15, 2005 | 11:07 AM
ger32's Avatar
ger32
Thanks bilder12 and others for good info.
It starts very well. I am in the process of studying this, many other uvo sites to see if I can learn enough to be confident enough to do the conversion myself. Any more tips will be appreciated.
jFa350
Jun 24, 2014 04:06 PM
8lug
Aug 26, 2012 12:14 PM
Deereguy90
Jul 27, 2011 09:26 PM
ghunt
General Diesel Discussion
Jan 4, 2008 02:56 PM
poston
Sep 19, 2006 09:49 PM
