Gear Ratio Question
Old Nov 10, 2005 | 02:03 AM
RotGrubestier44's Avatar
RotGrubestier44
Question Gear Ratio Question
hey yall, I was just wondering if there was any way to know what my rear end gear ratio is without jackin the truck up and doin the ol' "turn the driveshaft and watch the wheel turn" trick. Any help on this would be much appriciated. By the way, its a '94 F-150 4x4 with the 4.9L and a 5 speed manual trans. Thanks much.
Old Nov 10, 2005 | 02:08 AM
Cruiseomatic's Avatar
Cruiseomatic
There should be a metal tag bolted to the cover on your diff. housing with numbers on it,Post back with them numbers and someone should come along and translate them for you.
Old Nov 10, 2005 | 02:09 AM
Overkill-F1's Avatar
Overkill-F1
Do you still have the sticker on the driver's side door post? It will list an axle code. ...Terry
Old Nov 10, 2005 | 02:10 AM
RotGrubestier44
gimme a sec and ill go look
Old Nov 10, 2005 | 02:12 AM
RotGrubestier44
axle code on door sticker is 18
Old Nov 10, 2005 | 02:21 AM
phoneman91's Avatar
phoneman91
You have a 3.08 open differential.
Old Nov 10, 2005 | 02:28 AM
RotGrubestier44
3.08 huh... good number if ur talkin ammo, but bad (IMO) since we're talkin rear ends. Looks like Randy's is gonna be sellin me a set of 3.73 LSDs REAL soon. Thanks for the help.
Old Nov 10, 2005 | 02:42 AM
Cruiseomatic
But is the rear diff. factory? Over the years people change them out,thats why I said check the diff. it's self. Although if it is stock the door sticker is a great place for the info instead of crawling on the ground.
Just thought I'd throw that out.
Old Nov 10, 2005 | 02:50 AM
phoneman91's Avatar
phoneman91
What's wrong with 3.08s and the 4.9 six combination? Sounds like a good combination for maximum gas mileage. What is your MPG??
I would rather have 3.08s than the 4.10s that I have on my F150 5.0 V8 --every time that I fill up at the gas station.
Old Nov 10, 2005 | 03:00 AM
RotGrubestier44
oh, I'm puttin 33" tires on it, and 3.73s are the best gears to allow for good gas mileage (Researched Fact). I drive 120 highway miles a day, 4 days a week, but on the weekends we all go muddin and stuff, so I need some versatility. my MPG is in the 20-24 range now. I have researched it extensively, and done some figures, and 3.73s are gonna give me CLOSE (+-2 mpg) to the same mileage.
Old Nov 10, 2005 | 11:56 AM
johnsonswamp's Avatar
johnsonswamp
It's even worse having a F-350 crew cab lwb 4x4 with 4:10's and a 460, 8-10 mpg is the best it'll get.
