hey guys
I am trying to remove the intrument cluster because the lights onthe passenger side of the cluster only work part of the time. My problem is that i cant figure out how to get the spedo cable off the back of the cluster. any suggestions will be appreciated
Thanks
David
Just a little hint, it's alot easier if you can disconnect the speedo cable under the hood and let it slide through the firewall as you pull your cluster out, makes access to the back alot easier.
