bad shake
Old Mar 26, 2002 | 10:46 PM
Mil1ion's Avatar
Mil1ion
bad shake
Old Mar 28, 2002 | 08:46 PM
Vampiro's Avatar
Vampiro
bad shake
like my post "canadian tire sucks" in general states my truck now has a terrible shake when in park and the brake is depressed. the mounts where replaced at canadain tire today. now it's worse than before.
any ideas as to what caused this, and how i can fix it
Old Mar 28, 2002 | 09:15 PM
Mil1ion's Avatar
Mil1ion
bad shake
Are wires hooked up in the proper firing order.
Btw, The problem is with the PERSON who did the work, not the company,it becomes a company problem when people complain right then and there about the work and can confront the employee right away.
I wouldn't blame C.T. for something an employee did unless they won't fix the problem free of charge.
Dennis https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=1733&.jpg
[i][font color=red]Calgary,Alberta,Canada[/font][i]
https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=3180&.jpg
http://community.webshots.com/user/mil1ion
[font color=green] Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon [/font]
Old Mar 28, 2002 | 09:19 PM
Vampiro's Avatar
Vampiro
bad shake
it fires right. it only shakles in park with the brake held down
im just a little rite now. i don't hold anything against C.T. just i wasted 136 bucks and my evening and it is worse than before
Old Mar 28, 2002 | 10:50 PM
79f3504x4's Avatar
79f3504x4
bad shake
Sometimes the engine/trans can be in a "bind".Loosen engine/trans mounting bolts a few turns.Move engine tranny around to a 'neutral' position by lifting with a hoist,large prybar,or by attempting to "powerbrake" in reverse and forward.I usually have the hood up so I can see the engine move.Do this a couple times then tighten all bolts.Of course you will have to block wheels & leave in neutral until bolts are tight.This will allow mounts to work like they should.This will solve a lot of odd vibration problems.Brian
Old Mar 29, 2002 | 12:44 PM
Vampiro's Avatar
Vampiro
bad shake
well 79f3504x4 i didi what you suggested and it did work! it shake is almost gone now! yay!
Old Mar 29, 2002 | 12:52 PM
beartracks's Avatar
beartracks
bad shake
I wonder if you might have some kind of power brake booster problem. Like a vacuum leak opens in the booster when you brake?
Bear Tracks
Old Mar 29, 2002 | 03:44 PM
Vampiro's Avatar
Vampiro
bad shake
well i think now i fixed it. it was a little of everything. i found a vaccun leak at the rear of the carbuator, losened the mounts like 79f3504x4 and powerbrake and turned a loose screw hidden in the mounts and the bad vibs seemed to almost disaper. and also my tranne gear indicator doesn't jump around much anymore. yay!
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
