Reply to Spoolings ?
Old Nov 9, 2005 | 11:19 PM
7secbu's Avatar
7secbu
I can't reply to your boost question because my thread got deleted for not using the classified section. Anyway I usually see 20 to 22lbs of boost depending on what gear it's in. Wish I had more.
Old Nov 9, 2005 | 11:35 PM
Phydeaux88's Avatar
Phydeaux88
22 lbs is about the max you will get cause the PCM will defuel above that point. You can put a relief valve in the Map sensor line that prevents the sensor from seeing more than 22 lbs. Since I installed mine I hit 28 to 30 lbs pretty easily might get more if I had a longer hill to work on.
