General Automotive Discussion
Maybe a silly question...
Old Nov 9, 2005 | 07:54 PM
Mudder's Avatar
Mudder
But i just realized I have no idea how a ratchet shifter work? how do u shift while your driving,im thinking about getting one for my manual transmission cause i heard some good stuff about them,but i have no idea how it works! Any info would be great! Thanks in advance
Old Nov 9, 2005 | 08:38 PM
pfogle's Avatar
pfogle
I don't think it would work on a manual, it's designed for an auto.
Old Nov 9, 2005 | 08:39 PM
Mudder's Avatar
Mudder
im sorry i ment to type manual!
Old Nov 9, 2005 | 11:14 PM
sierraben's Avatar
sierraben
But you did type "manual".
Maybe you meant automatic.
Old Nov 10, 2005 | 12:07 AM
bigdaddyII's Avatar
bigdaddyII
Heres another silly question.....Whats a "ratchet shifter"?
Old Nov 10, 2005 | 12:14 AM
Ford_Six's Avatar
Ford_Six
It's a shifter for an automatic, where when manually shifting you can only go one gear at a time, designed for drag racing so you don't miss a shift and hit neutral or reverse.
Old Nov 10, 2005 | 01:32 AM
DOHCmarauder's Avatar
DOHCmarauder
The Pro Stock cars use "Liberty" manual transmissions........each gear has it's own lever to slam when the time comes. I don't believe they downshift very well(no synchros??) and I've never seen one run on the street.
Old Nov 10, 2005 | 12:59 PM
chrono4's Avatar
chrono4
always wondered what a ratchet shifter was. learn somthing new everyday.
Old Nov 10, 2005 | 01:29 PM
76supercab2's Avatar
76supercab2
I'm sure there are different types of drag racing manaul transmissions but the one I've heard about is made by Lenco.
http://www.lencoracing.com/racetr%7E1.htm
It has 1 lever per gear, no syncros and you don't have to clutch to shift. The transmission is a series of planetary gears. Final drive is 1:1 and each gearset reduces the ratio. As you shift, you are engaging a clutch pack that causes the planetary assembly to lock up to a 1:1 arrangement. Once you've locked up all the planetaries, your in final drive and the trans is essentially a straight shaft through to the drive shaft. I have no idea if you can down shift this trans. Don't see why you couldn't.
