Tightwad Tech: Cheapo Overflow Tank
Old Nov 9, 2005 | 10:36 AM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Last night, in keeping with my taightwad nature, I fashioned a radiator overflow tank from parts I had laying about. The plan is that this tank is a temporary tank so I can run the truck and will eventually get replaced with a fancy chrome one.
I started out with some 2" black ABS pipe, a pipe cap, a threaded coupling, screw on cap, 1/8" brass fittings, and some conduit hangers. I made my tank approx. 15" long. From my rough calculation it should have a capacity of approx .8 gallons.
Here are the parts (I had already glued the threaded coupling to the pipe)
I drilled a 5/16" hole in at the botom edge of the cap and through the threaded couple below the threads and tapped them with a 1/8" NPT pipe tap
The fittings were installed, I used 2, 90 degree elbows that had 1/8" NPt threads on one side and a hose barb on the other. You could choose whichever fitting or combinations thereof that fit your application.
The oveflow hose from the radiator attaches to the bottom fitting, and a hose is run from the top fitting to below the frame in case of overflow of the oveflow tank (thats a mouthful)
A conduit hanger was used for mounting (I only had one, I will have to go out and buy another) I chose to mount it just ahead of the radiator on the drivers side but it could go just about anywhere
A little bit of black paint on the cap, attach the hoses, and bolt it in place and I'm all set
Since I had most of the stuff laying about my total cash outlay will be about $5 since I need to buy 1 conduit hanger and another bottom cap (I drilled my first hole in the bottom of it and then changed my mind...oops)
Now I need to run some temporary wiring to the ignition and switch, starter, fuel pump, alternator, and line lock solenoid (hehehehe) and maybe I can get the beast over to the muffler shop.
Bobby
Old Nov 9, 2005 | 10:45 AM
cigarxtc's Avatar
cigarxtc
That's neat. Not bad for a temporary solution. I don't know if I'd use that long term. Also, I don't know how cold it gets in New Mexico, but you might want to put a few ounces of coolant in the bottom so if any moisture gets in there before being used it won't freeze and crack the PVC. Keep on truckin.
Old Nov 9, 2005 | 10:46 AM
hotrod48's Avatar
hotrod48
Looks like a good cheapo fix. I got my nice fancy polished stainless 2 pint capacity overflow tank for $20.00 a year and a half ago at the Southwest Street Rod Nationals from C.W. Moss (Good luck finding one that cheap now ) Hurry up and get that truck running, I want to see that big ol' Caddy tear up some pavement.
hotrod48
BigF350
Ride Of The Week
40
Nov 22, 2024 11:45 PM
SteveBricks
Ride Of The Week
Feb 9, 2021 01:26 AM
HRDROKN
Engine Swaps
686
Dec 28, 2015 08:31 PM
bememe
Sep 10, 2007 12:33 AM
cookie88
29
Dec 20, 2004 12:27 AM
