Driver side window got busted out.
Old Mar 29, 2002 | 03:49 PM
bluemustang's Avatar
bluemustang
Does any one have any instruction for putting in a new one? I'm going to try and do it my self tomorrow. I have a 1975 F100, what other years will work? Any advise would help.
Old Mar 29, 2002 | 04:47 PM
Vampiro's Avatar
Vampiro
anything from 73-79 will fit in your window.
some broke my window last summer. it's very hard to change.
1 make sure all the old glass peices are cleaned up and removed
2 take your time. the window doesn't bend!
3 if you remove your trinalur window it helps
4 unscrew all the weather striping and whatnot. remove the screws. give more room to play around with
5 try sliding the window down into the slot and getting the gearing to catch the metal notch.
this is what i did, but i took me a few hours to get it right and almost 1 more new window.
hope this helps ya out bud
Old Mar 30, 2002 | 09:08 AM
79f3504x4's Avatar
79f3504x4
Much easier if you remove rear track assy[2 bolts],remove vent window.Install glass,hooking roller on regulator.then install vent window,roll glass up,reinstall rear track.Brian
Old Apr 1, 2002 | 07:29 AM
bluemustang
Found one saturday and it put in, it was pretty easy all I did was remove the vent window. took me about 30 minutes to put the new one in.
Thanks
Old Apr 1, 2002 | 03:35 PM
76supercab's Avatar
76supercab
Dunnrightmobile
35
Mar 3, 2012 07:46 AM
305mike
Dec 7, 2009 06:36 AM
cypress_303
1997 - 2003 F150
Jan 21, 2008 01:15 PM
dzzavid
May 11, 2007 08:44 AM
maison302
Mar 17, 2001 11:10 AM
