This might be what you're looking for. There is a lot of data fields. Not sure which or if one of them is the turbo temp.
This is for a 05/06 Lariat.
Push and hold the Setup and Reset buttons simultaneously and turn the key to the on position. When "Test" appears in the odometer, release the Setup and Reset buttons and you are in the DTC mode. Press reset to cycle through the data fields.
Nope... same procedure, use the odo/trip/engine hour/trip reset "stub" on the instrument panel. This works on many Ferd vehicles (I've used it on Expeditions, F150s, Mustangs, and a few others).
has anyone does this and found temps and stuff bc i tried and got nothin...when you mean on position like as in starting the truck or just when the glow plugs warm up?
I tried this today and it had coolant temp, and a bunch of things I didn't understand. I didn't see anything about the turbo, but then again I could be blind.
