Warn Hub install !
Old Nov 8, 2005 | 09:49 AM
RobertJohn's Avatar
RobertJohn
Question Warn Hub install !
I know....I know....I've searched and still can't find the install tech. for the Warn Hubs..
Any one have the link ?? It would be appreciated, greatly....
Thanks,
RJ
Old Nov 8, 2005 | 03:23 PM
nodakford's Avatar
nodakford
Piece of cake. Take the hubcap off. Take the lockring off the auto hub. I used duckbill pliers to do this. Take the hub out. Uou may need to tap on it, I used a rubber mallet. Put the Warn in. Put the snap ring in, after bending the end a little bit, then put the cap on and tighten the 6 screws. Took me 3-5 minutes to do mine. I cut the vaccuum hose to the hub, and installed a couple plugs in the hoses and ty-wraped them out of the way. Here is a link to a website with pictures, that I found here. http://community.webshots.com/album/85609276aVntVC
Old Nov 8, 2005 | 04:26 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
that is how i did mine also. a trick to getting the snap ring in is to insert one end and spin the clip in instead of trying to compress the spring side to side to get it in. remember to retorque the 6 allen bolts after a few drives.
