Help with rear axle
Old Nov 7, 2005 | 10:33 PM
ctomblin's Avatar
ctomblin
Help with rear axle
Hello Everyone! I have a 2002 Explorer sport 4WD and found that the rear seal has leaked all over the inside of the passenger side tire. I am not sure how much oil leaked out or long it has been like that. HOW BAD IS IT TO DRIVE IT THAT WAY??? How much is this going to cost me to get fixed?
Thanks.....
Old Nov 8, 2005 | 05:27 AM
Beast12's Avatar
Beast12
Hi and welcome to FTE! Be sure to read this to help you around this site: https://www.ford-trucks.com/forums/s...d.php?t=300691 There are also State, Provincial and International Chapters located near the bottom of the main forum page.
We are glad to have you. Hope you enjoy the site. Check out the various forums. Lots of great info for you.
Thread moved to Explorer forum.
See ya on the boards!
-Matt
Old Nov 8, 2005 | 12:38 PM
Jharger's Avatar
Jharger
Isn't this a independent rear? If so, it's likely a constant velocity joint and it's grease that's spun out of the boot. This can be minor or major depending on how long it's been that way, how much grease is left around the joint and how much dirt and water have gotten up in there. So you might be able to clean it up, regrease and install a split boot or you might need to replace the entire axel shaft.
Old Nov 8, 2005 | 02:15 PM
bradcdavis00's Avatar
bradcdavis00
No, the Sports are the older solid axle design. They will need to remove the axle on the bad seal side, replace the seal, put it all back together. I had a quote for under $200 to do it. It needs to be done but make sure your differential oil level is good before going to much further.
Old Nov 8, 2005 | 04:50 PM
maa139's Avatar
maa139
Also, since the gear oil needs to be drained and one axle pulled out....might as well have them replace the oil seal on the other side as well...
Old Nov 8, 2005 | 10:05 PM
ctomblin's Avatar
ctomblin
rear axle
Thank you all for the advise on the rear axle. With all the oil like substance on the inside of my tire I was advised that it was the rear axle and that I need to replace the seal. I took my Explorer into have my oil changed so they can check the differential fluid and make sure i wasn't to low to continue driving it and the mechanic there advised me that the problem is with my brakes. I am leaking brake fluid from inside the chamber(if that is what they call it). He checked all the lines and they are clean therefore its something internal. ANY ADVISE on this and how much this might costs me.
Thank you again
Old Nov 9, 2005 | 05:06 AM
Beast12's Avatar
Beast12
Oh, it is probably a leaky wheel cylinder. Those are fairly cheap (less than $20) and easy to fix. You MAY have to replace a small piece of brake line as well.
-Matt
Old Nov 9, 2005 | 11:09 AM
bradcdavis00
Does your 02 Sport have rear disc brakes? I just checked PartsAmerica and thhey show that it does. A remanufactured rear caliper for your truck is $36. If you do the work your self you will need to bleed the brake line after installing it. It is not that difficult to do. I am not sure what a mechanic would charge you for the work. Shouldn't be over 2 hours labor, say $140, parts and new brake fluid- $50. Under $200 is my guess.
Old Nov 9, 2005 | 08:17 PM
ctomblin's Avatar
ctomblin
Thank you. I will not be doing the work myself but hopefully I can get my uncle to do it.
Thanks again
