Aluminum Driveshafts??
Depends what you mean by "best"! An aluminum alloy driveshaft can certainly be designed to be plenty strong and would be much lighter than an equally strong steel shaft. However, it would cost much more.
Ford had done a lot of work on their strength to weight ratio in order to get their trucks as efficient as possible. Unfortunately, they now have to cut manufacturing costs, so much of this is being reversed.
While were on driveshafts, I noticed when I re-installed mine it would slide back in the tranny splines and not have to be lined up just like it came off. I thought they had to be lined up to go together and to be properly balanced. There was a white paint spot on the tranny splines and a groove in the drive shaft splines, but they were not lined up originally. They were 180 degrees off. Mine seems fine,but I don't think it is the same as what it was originally. Any thoughts or comments would be appreciated. Thanks.
putting the drive shaft back on the way it came off is from the old days, when a drive shaft is ballanced it is not on the car but on the factory floor. then installed. You gotta think what happens when you change out your tranny or rear end does it throw the ballance off NO if you put it back on a different way than it came off does it throw the ballance off, no. The drive shaft is ballanced not the shaft to the truck. If you do buy a alum for the truck will they ballance it to the truck? no they will sell it to you in a box and you install it will it throw the ballance off no.
Lance
Lance
KawiRider78
05-07-2011 12:30 PM
Ultramagdan
1997 - 2003 F150
10-25-2001 08:30 AM
