Power draw
Old Nov 7, 2005 | 05:53 PM
shadowdd's Avatar
shadowdd
Question Power draw
I have found out what fuses are causing the largest draw on my battery. When I checked the draw with the amp meter it read .48 amps. I pulled all the fuses untill I found some that dropped the draw to .10 amps. THe fuse numbers are 103 and 110. Both are 50A fuses and in the owners manual it shows to be for the ignition switch. Does anyone have any idea what could be causing this to cause such a draw or if this is normal? I read about a fuse that controled the GEM module and I was wondering if this GEM module could be out on my truck. Any help would be great. I have a 2003 limited X with a v-10.
Thanks, Bryan
