Modular V10 (6.8l)
Another radiator clamp leak
Old Nov 7, 2005 | 01:58 AM
V10man's Avatar
V10man
My first leak was the large hose going to the thermostat. (https://www.ford-trucks.com/forums/s...d.php?t=390027) The dealer replaced the squeeze clamps with screw clamps. Now the heater hose comming off the front of the engine leaked! No where near the mess the first leak caused. I don't feel like wasting a couple days at the dealer so I'll probably fix this myself.
Both times I was towing and having to run in the 4000+ rpm range. I'm wondering if the water pump is spinning too fast making too much pressure.
Old Nov 7, 2005 | 09:26 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
I doubt it's the pressure from the pump
You should report it to the dealer, just in case something else happens, like overheat damage, you'll have a leg to stand on.
Old Nov 7, 2005 | 04:08 PM
biz4two's Avatar
biz4two
I agree with Krewat. The dealer should be made aware of the new issue for documentation purposes...if any thing. Of course...this is said only if you are still under warranty. JMO...
biz
