help! body lift problems
Old Nov 6, 2005 | 07:45 PM
Andrew16's Avatar
Andrew16
i hav a huge problem!
i jus put a body lift on my 1994 f150 xl I6 automatic transmission truck and now my 4wd is stuck on! that happened when i lifted it. its lifted 3 inches. how do i unstick the 4wd?!?!
thanks
Old Nov 6, 2005 | 07:49 PM
frederic's Avatar
frederic
You have to "adjust" the hole in the floor the shifter goes through. When you lift the body, and not the drivetrain, you limit the movement of anything mounted underneath the floor.
Pull up the carpeting and you'll see what I mean.
Old Nov 6, 2005 | 07:52 PM
Andrew16's Avatar
Andrew16
how exactly do i "adjust" it?
Old Nov 6, 2005 | 08:09 PM
Andrew16's Avatar
Andrew16
so do i just have to cut the hole bigger where the 4x4 boot is?
Old Nov 6, 2005 | 08:28 PM
frederic's Avatar
frederic
Yep.
Before you cut, make sure it's interfering there first, of course.
Old Nov 6, 2005 | 08:33 PM
Andrew16's Avatar
Andrew16
so its just that simple?
Old Nov 6, 2005 | 09:30 PM
frederic's Avatar
frederic
If the lever is hitting, yes.
When you lift the body, you're moving the hole further up, and mechanically that's the equivilent of making it smaller.
Old Nov 7, 2005 | 11:16 AM
first time 4x4's Avatar
first time 4x4
I put a body lift on mine with a standard trans. and had the same problem but with both shifters. Instead of cutting the hole bigger I just heated up the shift levers red and rebent them to where i wanted them. This way I could reuse all the factory interior pats and have a very nice looking finish. BTW I removed the shifter from the truck to heat up and bend.
Old Nov 7, 2005 | 11:25 AM
dale gribble's Avatar
dale gribble
That's the way to do it right there first time 4x4. Course, I am sure a notch on the body would work too. It can't be too far off.
I like the 'BTW'- good advice! Burnt carpet STINKS!
Old Nov 7, 2005 | 12:52 PM
frederic's Avatar
frederic
It's probably off an inch. I made the assumption it would be easier to nibble out the opening a little bit, versus torching the handle and bending it.
Old Nov 7, 2005 | 08:50 PM
ssn randy's Avatar
ssn randy
torch the handle. if you don't it could mess up the travel of the shifter (i.e. hitting the dash or seat) measure twice and bend it once--remove the ****. mine has a bend right at the floor and cutting would not work.
Randy
Old Nov 7, 2005 | 09:03 PM
Andrew16's Avatar
Andrew16
so when i remove the shifter from the vehicle i just unclamp it fom underneath? i tried loosening the clamp, but i cant get it pryed open enough to take the shifter out. any suggestions on how to get the shifter off the truck? how bout removing the ****?
Old Nov 7, 2005 | 09:07 PM
ssn randy's Avatar
ssn randy
loosen them some more, spray it with WD40, it will come off. try twisting as you lift it. do a search for removing the ****
Randy
Old Nov 7, 2005 | 09:08 PM
Andrew16's Avatar
Andrew16
ok thanks, ill give er a shot
Old Nov 7, 2005 | 09:33 PM
ssn randy's Avatar
ssn randy
i did this to mine, so i can say it does work
Randy
