intermitent power to ignition
Old Nov 6, 2005 | 07:08 PM
alz's Avatar
alz
Three times this has happened now. I turn the key and I get no start. The idiot lights come on very dim and kind of flicker. I try turning the key off and then on again a couple times just to the acc position, and then it lights up. When that happens, it starts right up. So far it hasn't left me stranded, but if there is a fix, I'd like it done.
Old Nov 7, 2005 | 12:40 PM
96hulk's Avatar
96hulk
Check the wiring on your starter there is a small blade type connector on a 16-18 awg wire that was loose (still is i'm lazy) on my truck that makes it start differently every time i turn the key, a few times in the winter this prevented the truck from starting until i reached down through the engine well with a broom stick and moved the obviously loose wire. My guess is the simplest solution (at least for the problem that i have) would be pulling the connector off the "tab" and bending the connector with a pair of pliers so that it makes better contact when placed back on the tab. Maybe a little dielectric grease will help too.
Old Nov 7, 2005 | 01:34 PM
quicklook2's Avatar
quicklook2
had to clean and tighten my spade connector also.
Old Nov 8, 2005 | 06:51 AM
alz's Avatar
alz
This happens before I engage the starter. When the key is in the acc position. Once the lights come on normal, I turn the key and it starts right up.
95 f150
Old Nov 8, 2005 | 09:09 AM
alz's Avatar
alz
Sorry, when the key is in the "on" position. Not back to the acc position.
