98 Explorer 4wd Brake Bleeding
Old Nov 6, 2005 | 05:40 PM
truckbutt's Avatar
truckbutt
I changed the front pads on my 98 Explorer 4WD today. I hadn't done them myself before but I felt a little brave after doing front and rear brakes on my 88 jeep last weekend. The new pads and slides went in without a problem. I made sure that the brake fluid resevoir didn't get to low as I drained fluid prior to compressing the pistons. I was surprised that even though I hadn't disconnected the brake lines that I needed to bleed the front brakes. It took 3 times on each side to get the pedal hard. Why the need to bleed the brakes if the system is closed?
decaruby
Mar 28, 2011 01:05 AM
jleo
Apr 4, 2010 01:29 PM
DirtySCREW
1997 - 2003 F150
Sep 19, 2009 03:50 PM
Elephant
Aug 30, 2009 02:32 AM
stvokc8885
Nov 22, 2002 10:48 AM
