The Modulator is generally very easy to replace. It would be on the side of the transmition and the only thing with a vacuum line going to it. When you pull the vacuum line off of it and ATF comes out of the line than we have found the problem. Ones I have done on 3 speed autos and the A4OD where all held in with on bolt holding a clamp. My last modulator cost me around $20.00. On the little 1990 Ranger I just did I had to cut a hole in the floor to get at it. Once there it took like 10 minutes to R&R (Remove and Replace). I do not think you have to cut out your floor on a full size rig. It should be very easy to get at.
OK.....NOW i know EXACTLY what you are talking about Because my 28 STUDEBAKER RAT ROD has a 350 automatic with a modulator so i went out and lay down under the Diesel and checked BOTH sides of the tranny.......NO vacumn lines and NO modulator that I could see......NOW what????????
I'm not a Marine, so forgive me...Semper Fi!
Anyway, step back for a moment and consider that the ATF is going somewhere!
It drove two hours (it didn't do that on zero fluid) and you keep pumping more into it. If it's not puddling on your driveway, it's going somewhere else. Where else can it possibly be going?
I had an E4OD, and hated it. I don't know about the diesel, but there should be a vacuum connector from the tranny to the engine. I'd certainly look for that.
I hear ya PaPa bear.....I only had this 3 days and I am only driving it around the block once or twice untill i figure it all out.....I have NO clue as to IF it was FULL of tranny fliud when the BOY left Riverview or NOT??? His father died,,,The truck sat up over 2 yrs and now I bought it.....IF...and only IF we determine the tranny is ACTUALLY BAD.....then IF i have to swap it out,,id rather swap it out for a 5 speed.....BUT...I DONT want to just throw GOOD money away IF the actual tranny is ok?????? BUT......again IF its BAD......Where do i look for a 5-speed MANUAL,,,,,Bell Housing....CLUTCH/pressureplate/throw-out bearing/Fork and 5 speed maunal PLUS BOTH the CLUCTCH PEDAL & Brake Pedal??? I know you are going to say JUNK YARD but i DONT want to but a tranny from a junk yard??? So for Now I am going to fill the tranny TOMORROW completely FULL and watch daily to see IF it in Facts keep DISAPPEARING then PULL OUT ALL MY HAIR...LOL
Yes look for a vacuum line on the tranny. Pull it off and if it has ATF in the line we will go from there. Like maybe get into the right forum for this so the guy's that know can see it and help. Wish I knew who that would as I would send them a PM and ask them to check in. Anyone know?
I DID ly under my trck and looked GOOD and saw NO MODULATOR and saw NO VACUMn line going to the tranny from EITHER side and again..as i lay under there looking...The tranny pan is HIGH & DRY
LOL......I myself PREFER a MAUNAL but MANUALS are very HARD to find with the 7.3 in FLORIDA so I had to get this one,,,Will try adding fliud till its FULL......Watch it like a HAWK and IF All else FAILS.....HOPE & Pray I can SWITCH everything OVER at a very CHEAP-CHEAP Price???? LOL
okay at the very top of the page hold the cursor over forums. scroll down to these and post your problem there. These boys will know and I will follow along bud.
NumberDummy had posted some part numbers for switching over to a manual transmission - it's a big job!
Clutch pedal
Hole in floor
Flywheel
Starter
Column shift
different brake pedal
different pedals shaft
I don't remember why the brake pedal was different, but mounting the standard tranny is the easy part.
Colomn Shift????? I want a 5 speed Manual shift on the FLOOR IF I have to replace the automatic....thought about just breakin Off the p/r/n/d/2/1 indicator on the sterring wheel and SMOTTHING it down smooth with the sterring column already there since i was installing a standard tranny in the FLOOR....That way i wouldnt have to change sterring columns????
again my friend......I DONT know a lot about computers and this is my very FIRST Forum I ever did and at 60 yrs old...ALL this FANCY stuff IN the Forums are WAY over my head for a First timer..LOL Sorry....
No offense, but NumberDummy and others here are all about doing a job right, with the right parts, and to completion. If you choose to go a different route, we'll help you as best we can...
I am 60 also and live in the bush. A logger and old mechanic. What do I know about computers. If ya can't fined the word forum at the top of this page how do you even make a cup of noodles?
