Centurion Package
Old May 5, 2012 | 01:05 AM
kbrenner536's Avatar
kbrenner536
Old May 5, 2012 | 02:16 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Devil-Dog
Im a 100% Service-Connected MARINE Disabled Viet Nam Vet and I am 59 yrs old and this is my very FIRST Diesel truck and I know i have a LOT to learn.
VIN: 1FTHX25F2TEB28304 if that HELPS to really find out EXACTLY what I do have?
1FT = FoMoCo USA ~ Truck Complete Vehicle
H = 9,001-10,000 lbs. Gross Vehicle Weight Rating Range.
X25 = F250 2WD Super Cab Pickup.
F = 7.3L Turbo Diesel.
2 = Check Digit-FoMoCo use only.
T = 1996.
E = Kentucky Truck Assembly Plant.
B28304 = 1996 Numerical Sequence of Assembly, the trucks specific serial number.
The TRANS code is listed separately on the Certification Label, but with a 7.3L, it's an E4OD.
Old May 5, 2012 | 12:25 PM
hasteranger's Avatar
hasteranger
For what forum chatter is worth, I've seen it here before that centurion did not start doing the 4 door bronco's until sometime in the 80's, an people call their 70's ones centurions as a generic name and they are usually home brew creations. I have no way of knowing if that is true or not, but that was the consensus on a couple of other threads years ago.
There is a dealer in Martnsburg, WV, that had 2 of the late 80's 1/2 ton centurions and one 1996 superduty diesel centurion. All of them had a ton of rust and were not well taken care of.
what I do know about the 80's ones is that they didn't really graft "the back half of a bronco" onto the truck. They just made their own molds for the seal area and used a bronco top. They then cut the truck on the bedsides, cab roof, and back of the cab, and grafted the rear area onto the truck. they used a TON of bondo, and almost every one I've see, both locally and online, has big cracks running across the roof where the weld seam is, and rust underneath where the cracks have let water in. Its also very common to see bondo cracks where the quarter panels are joined together. The trucks had the stock bed floors cut out as well, and new ones welded in. All 3 of the trucks at the dealer had very heavy rust (through the floor boards and wheel tubs) throughout these weld seams. and be to honest, on all 3 of those trucks, the mentioned rust from the conversion seams was the only rust on the entire trucks. Which makes me think that even though people think "centurion" means it was professionally done, it doesn't really matter if centurion made the 70's ones or not, since their methods weren't much better than your typical body shop would do f they did one today, and apparently they didn't spend a dime on rustproofing.
Old May 5, 2012 | 02:49 PM
punkrockpilot's Avatar
punkrockpilot
thats funny I just saw that ad a little while ago and saved the pic cause i thought it was pretty cool.
Old May 5, 2012 | 02:57 PM
Devil-Dog's Avatar
Devil-Dog
Thank you for the help my friend Now IF I can find out what the numbers in my CENTURION Decal mean......2285870....I tried 7 times to UPLOAD a picture of My f250 but it WONT reduce it to needed size to post..keeps saying failed attempt & i DONT know how to reduce it???it automatically reduced My other 3 cars but WONT reduce the Ford???
Old May 5, 2012 | 06:27 PM
"Top Fuel" Bender's Avatar
"Top Fuel" Bender
I use this Batch Picture Resize
you download it to your computer desktop
then you can click and drag any photo over the picture-resize icon on your desktop
a box will pop-up if you want to customize anything (which you shouldn't have to )
just hit enter and it puts the re-sized photos back in the same folder you pulled it from
that simple
the new photo will have the same name with -800 or -400 behind it (depends what you resize it to)
if it's still to big you can take your resized pic and do it again to make it smaller if you want
Old May 5, 2012 | 10:57 PM
arctic y block's Avatar
arctic y block
Hey Bud go here to re-size yer pic's. It's as free and easy as it gets.
Free Online Image Resizer - Photo & Picture Resize & Crop
Old May 6, 2012 | 07:41 AM
ctubutis's Avatar
ctubutis
Only paying Supporters can directly attach files to posts, the rest of us need to upload them to a hosting service (which can be FTE Albums if one so chooses) and then use the IMG code to make them appear inline in posts.
IMHO it's confusing in that the forum software offers to anyone to attach pictures, it just fails to work for non-supporters. C'est la vie, I guess.
Old May 6, 2012 | 08:43 AM
perky's Avatar
perky
Photobucket is the easiest to use.it resizes the pictures for you when you post them to other sites.
Dale
Old May 6, 2012 | 09:21 AM
bruno2's Avatar
bruno2
This truck is sweet!
Old May 6, 2012 | 05:00 PM
Devil-Dog's Avatar
Devil-Dog
Thats a HUGE help but NOW I have had My truck LESS than 3 days and ALREADY DREADING buying it!!!!!! for you see I CANT ask a DEAD MAn what he did to the tranny.......It slipped from the Start since I got it PLUS ONE injector ISNT working so I finally was SMART enough to check the tranny fliud.......NOT touching the STICK at ALL......So.....I added 3 QUARTS......Still NOT touching the STICK.....I had found in the took box in the Back of the truck where there was a transmisson FILTER & GASKET so did He change the Tranny and NEVER got around to filling it up?????? His Son DROVE it to ME from riverView which is TWO Hours away and HE claims He knows NOTHING about it.........At This point ALL I can DO is Keep ADDING fliud UNTILL its FULL then start watching for LEAKS but So Far the 3 days I have had it NOT a Single leak........Did the SON Hurt it driving it TWO hours LOW on Fliud bringing it to Me?????? I DONT KNOW......Quess thats what I get for NOT checking it out MYSELF.......HOPE It all turns OUT well & I DONT have to BUY another tranny.........Just Trully Bothers Me cause I already added 3 quarts that i already HAD & still NOT touching the Stick......................
T = 1996.
Old May 6, 2012 | 05:20 PM
arctic y block
I hope it ain't hurt as well Bud. It had to have fluid in it when the kid brought it to you or he would have had to tow it. No one has said yet if it has a vacuum modulator or not. IDK for sure. But if it does and has no leaks than my thinking and experience says the diaphragm in the modulator has a hole in it and is sucking the fluid into the engine and burning it. Being it is a diesel you would not see the smoke from burning the ATF as I did on my A4OD. They can drive just fine and even shift fine if the diaphragm isn't torn to badly. But still eat ATF like crazy. One good thing is it will SUPER clean the combustion chambers now let be tell ya.
Will someone chime in and say if it has a vacuum modulator please.
Old May 6, 2012 | 05:35 PM
  #28
Devil-Dog's Avatar
Devil-Dog
I Wish I knew but i DONT...tomorrow I will go to parts house and buy another 5 qts and add it and AFTER I get it FULL then I will start watching it DAILY for myself to check it....WORSE case lets say it DOES have this Modulator and there is a rip or tear....then whaT??????? Just replace MODULATOR and what cost or replace trany.........I DO have the EOD something someone said because of the 7.3 TURBO??????
Old May 6, 2012 | 05:38 PM
  #29
Devil-Dog's Avatar
Devil-Dog
Old May 6, 2012 | 05:43 PM
  #30
Devil-Dog's Avatar
Devil-Dog
In order to Build what i want to build with this Diesel truck i need to SELL one or TWO of my other toys in my garage..I have pictures of all 4 of my toys in Devil-Dogs Garage & Devil-dogs garage 2....For Sale are My 2007 Hummer H3.....my 2007 BULLDOG CUSTOM motorcycle and finally my 1928 STUDEBAKER 383 Stroker FULL BLOWN RATROD Pick up...HELP your self to view the pics....IF anyone wants MORE pictures or info you cam email me at......spideronthewallwatchingitsprey@yahoo.com.. ...thanks
